Old 01-04-2004, 04:06 PM
DeaconEJ DeaconEJ is offline
Question Driver's door problem!
Happy new year!
How can I open the door when the outer handle is broken and when I pull the inner it doesn't work! ('91 3.1 euro)
Old 01-07-2004, 12:10 AM
kenseth17 kenseth17 is offline
is there a cover with a screw over the door handle part of the inner door handle you can remove, haven't seen a lumina door panel lately. You will have to find someway to get behind the door panel, maybe remove any of the screws in the door panel, and pop the door panel out, probably plastic push clips holding it on. If you can reach your hand behind the door panel find the rod that comes from the door handle and pull it to open the door. Once you got it open take the door panel off and find out is wrong with your handles and fix them so you won't have to go through it again.
Old 01-07-2004, 12:42 AM
Thanks for the advice! The problem comes from the seat - I cannot move it that much so I can open the panel, but I will see what can I do.
02 Town and Country Lmt, FWD - Clunking from front end and power door problems confused81 Caravan | Voyager 12 08-06-2010 10:19 PM
Driver's Door Lock switch problems 95 Camry 69eliminator Camry/Camry Hybrid/Vista 0 12-14-2007 03:29 PM
1998 Kia driver's door locking mechanism problems skutter Sephia 1 01-01-2006 10:08 AM
Driver's Side Door Problems? prismperfect Grand Prix 0 03-30-2004 10:33 AM
