Cant stop the smoke!
Hi,
Took my hatch out driving for the past 2 nights and the car smokes pretty bad when u rev past 3500 RPM's. So as long as you drive normally and shift at the right rpm's there is no smoke. However, when you race or rev it past about 4k smoke pours out. Its white smoke BTW. Anyways, someone suggested Smoke Away because his dad puts it in his 88' Benz. So I changed my oil and added the Smoke Away like the directions said. I put about 60 miles on it with no results. So last night while driving wit my friend we stopped into Wal-Mart and I bought a bottle of "Slick 50 Engine Treatment For High Milaege Engines" We added the bottle and put about 20 miles on it with my friend driving behind me and he said it didnt smoke as much. But my question is, how long do you have to wait to see results with this stuff? I know it wont remove all the smoke, but it should help to clear a big portion up. Thanks
1990 Honda Civic LX 5 Speed 1.5 Liter SOHC K&N Cone Filter APC Short Shifter 1988 Honda Civic STD Hatch |
i have no idea how long it should take before it starts to work but by the sounds of it, ur head gasket is shot, replace it and it should get ridda the smoke
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
Re: Cant stop the smoke!
could be that or your rings.
Ok I was also told by some people its the head gasket.
I wanna save the money and do it myself, but just how hard is it to do? Is it something I could get done in a weekend? How much is the head gasket? Do i just follow my repair manual on how to do it? Any other gaskets to replace when I do this? Thanks
ZC stuff http://dh-racing.com http://www.thezcr.com/html/zcbook.php http://dmoore.com/crx/zc.htm http://www.jgenginedynamics.com/HOME%20PAGE http://www.theoldone.com/
yup, somehow coolant is getting inside the combustion chamber and getting burned explaining the white smoke that is coming out your exhaust. This points to a blown or bad headgasket. Yes a headgasket can be done in a day. Sorry your oil additives will not help with getting rid of the smoke.
-1991 Civic Si (Sold) -1990 Accord EX(Sold) -2000 Civic Hatch -1998 Lexus SC300 ![]() Click here to see my Shoe! |
not only is it possible the headgasket is bad or blown but dont forget there is a possibility of a bad intake mani gasket also. though it doesnt sound so bad being it pours smoke out at over 3500rpm or so. as far as the work is concerned IMO the hardest part is getting that 12mm nut off of the bottom of the intake manifold, it always gets to me.
im thinking it might be your rings. do you have oil resadue on your back bumper. i only say this because you say it happens at around 3500 rpm.
if it is your head gasket its a easy job took me 2 1/2 hours most of the time was to get the old one off and clean up the carbon biuld up. |
Re: Re: Cant stop the smoke!
Re: Re: Re: Cant stop the smoke!
Nope no oil residue on the back bumper.
I wanna replace the head gasket soon, possibly this weekend. I got a D16A6 engine out of a 90 CRX SI and I am practicing taking it apart and looking at the head gasket and rings. So when I do it to my hatch i shouldnt hopefully mess it up. How much do head gaskets cost at Autozone?
I'd be willin to bet that it is your head gasket. Mine was like that for the longest time. And then it finally gave up. Check your over-fill radiator tank, it's a white little tank that usually has anti-freeze in it unless it's oil like mine. Take it out and see if it is dirty. Also check to see if it lowers ever.
Yea, im almost 100% sure its the head gasket because I checked the overflow coolant tank and it has oil in it.
I did the SI engine and took the head off in about an hour, not bad for the first time. So what you do is take the old gasket out and scrap the stuff out so its smooth, right? Can I use a sharp razor, like for removing window tint to smooth it out? DO I have to use a sealant for the gasket? Thanks
I checked the coolant resevoir one more time and it was completly covered in oil around all teh sides and floating around in the green coolant. So it definetly should be the headgasket right?
Thanks
yep that would be ur headgasket gone
and dont use any gasket sealer either, you dont need it, when you torque the head bolts, it will squish the gasket making it seal
