Old 01-04-2004, 10:00 AM
super GT super GT is offline
Banned
who would win?
my friend is driving a 1995 mustang gt auto, vert with just pulleys and a cold air intake. what kind of 1/4 mile times would he get. He wants to race a guy with a 2001 mustang v6 5 speed coupe stock. who do you think would win??
Old 01-04-2004, 10:38 AM
eillob's Avatar
eillob eillob is offline
The 95 hands down. 1/4 mile times, probably high 14s or low 15's. Tell your friend to get a gear change asap. With an automatic convertable your dealing with the worst of both worlds. My suggestion would be 4.10s or 3.73s
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 01-04-2004, 06:13 PM
parrish5o's Avatar
parrish5o parrish5o is offline
Re: who would win?
eillob
are you running a recalibrated stock MAF or an aftermarket and just out of curosity why such large injectors? The 19lb factory pieces would be more than enough to supply a engine with your parts list. When I swapped my 24s for 30s there was no obivous performance gains but my milage dropped, so I'm thinking of putting the 24s back in. I have an appointment with Panhandle for some time on the dyno next week so I'll wait until I get some figures before I decide.
CANFIELD STAGEII HEADS SCORPION 1.6 COMP CAM 555/570
GT40 INTAKE STAGEII LOWER 65MM TB PRO-M 75MM MAF
30LB INJECTORS 190LPH FUEL PUMP/ NOS INLINE PUMP
FMS ZT5 CENTERFORCE CLUTCH HURST SHIFTER
ALUM DRIVESHAFT 31SPLINE MOSER AXELS AUBURN DIFF
ALUM RADIATOR MSD 6AL MSD ADJUSTABLE TIMING RETARD
NOS STAGE II 150HP 497@5800 474@4300 11.3@118
Old 01-04-2004, 07:17 PM
eillob's Avatar
I changed my MAF sensor for one calibrated for 30lb injectors. The reason I went with larger injectors is because im adding a 100 shot of nitrous. Also in the next couple of months I plan on swapping the motor for a 347.
Old 01-04-2004, 07:25 PM
parrish5o's Avatar
Re: who would win?
Thats what I figured, I have heard alot of different opinions on injector size vs hp. I say it's better to go a little bit than to run lean, good plan, and cool car.
Old 01-05-2004, 10:21 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: who would win?
not only that, but a set of smaller injectors with the pressure turned up is better than larger with the pressure turned down.
because of atomization, etc.
Mustangs are nice, but I'd rather have one of these...
