Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 01-04-2004, 08:55 AM
Ben944 Ben944 is offline
Send a message via AIM to Ben944
ball joints
I think i need new ball joints. but does that mean getting all new control arms, or can i just press out the old ball joints and press in the new ones?
thanks
Old 01-04-2004, 11:37 AM
Re: ball joints
btw i have a 1983 944
Old 01-06-2004, 01:16 AM
YeTi's Avatar
YeTi YeTi is offline
Send a message via AIM to YeTi
Re: ball joints
no...
acually, you could swap the a-arms with those off of a VW rabbit, if it is cheaper than new balljoints, because they are one in the same.
YeTi
Old 01-06-2004, 03:50 PM
Re: ball joints
what are you saying no to? i can get ball joints for $18 a pair.
Old 01-06-2004, 08:32 PM
YeTi's Avatar
Re: ball joints
i was saying no that you didn't need to get new a-arms
YeTi
Old 01-06-2004, 09:56 PM
Re: ball joints
thats what i was hoping. I had to get new control arms for my BMW, those things are friggin expensive.
thanks
Old 01-17-2004, 08:04 PM
alocowgirl alocowgirl is offline
Re: Re: ball joints
Will the fix noted below for an 83 944 work for an 87?
thanks
Old 01-19-2004, 11:22 PM
YeTi's Avatar
Re: ball joints
no because in 1985.5 the 944 lsot the heavy VW a-arms and aquired lighter cast aluminum a-arms with the balljoints built in.
YeTi
Old 01-25-2004, 08:35 PM
Travis @ Rennbay Travis @ Rennbay is offline
Re: ball joints
If you need ball joints for the aluminum arms just do a search on Google. Maybe something like "Porsche 944 ball joint kit" or similar. Someone out there makes kits to rebuild them I think
Rennbay
Old 02-10-2004, 01:37 PM
panzergrey panzergrey is offline
Tsb
Porsche put out a technical bulletin about ball joints being damaged from excessive lowering of the 944.
I can't find the link right now.
Old 02-10-2004, 03:17 PM
link to Porsche statement on ball joints
Found the Link !!!
http://www.connact.com/~kgross/FAQ/944faq10.html
FAQ on suspension.
Old 02-18-2004, 03:10 AM
944Fan 944Fan is offline
Re: ball joints
If your 944 still has the early steel arms the ball joints will unbolt,if its been updated to 86- alloy arms then ball joints kits are available
