Old 01-04-2004, 12:31 AM
'86z28 '86z28 is offline
'86 z28 won't start, i just started it two days ago
here lately i've have been preping my camy for a new paint job, so for about a week i had my hood off etc. well i had been driving this car daily, all the time and it worked perfectly. for some reason i decided to wait on the paint so i put it back together and cranked it up, it drove very crappy then, i look down and saw that i basically had no gas so i figured i just was running out of gas. i drove it to the front of my house. then a couple days later i went to crank it up and it won't crank at all. it turns over fine. i looked in the carb and it is getting gas fine. at first i thought i was just out of gas so i got some to put in the tank and even pour a little in the carb. it still won't crank, i replaced the spark plug wires, the distributer cap and rotor. plz help me
Old 01-04-2004, 01:11 AM
crapmaster4000's Avatar
crapmaster4000 crapmaster4000 is offline
Did you check your coil, It could be bad or check all your wiring connections.
Old 01-04-2004, 06:09 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: '86 z28 won't start, i just started it two days ago
could also be a ICM. ignition control module. if that went then it wouldnt start. also, check all your fuses. there are ignition fuses in the panel under the driver instrument pannel. near the pedals. but so long as you have fuel, its definately an ignition problem.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
