Old 01-03-2004, 06:43 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
351W pistons
time to get picky.
i need a set of pistons. they need to make 10.5:1 with 61cc chambers. bore 4.03, stroke 4, rod 6.25, pin .927. that's about it. any suggestions as to brand, or even specific links? thanks =)
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 01-03-2004, 09:11 PM
boosted331 boosted331 is offline
Re: 351W pistons
Originally Posted by StangNut86
time to get picky.
As far as I know, nobody makes a shelf stock piston exactly what you want. Any of the piston manufacturers will make you a custom piston though, you want a 17CC dish assuming a .045" deck height with a 61CC chamber to give you 10.5:1 compression.
Old 01-03-2004, 10:18 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: 351W pistons
i think trick flow may have what your looking for, it may have just been 10:1 that i saw though.
Old 01-03-2004, 10:40 PM
Trick flow pistons are for a 6.2" rod and have twisted wedge valve reliefs, so I don't think they would work with a normal head, nor with a 6.25" rod.
Old 01-04-2004, 01:54 AM
i'm actually still flexible on my rod length and such. and i'm using the trick flow twisted wedge type r heads, so those pistons wouldn't be a problem. thing is, they just don't make the compression... it's either too much or too little. but, i'm getting with the guys at Probe to have some custom pistons machined sometime in the future. i'm not set on brand either, but i've heard some convincing arguments for those guys.
now, here's a stupid question: what exactly is compression height, and deck height? clearly, i still have a lot of research to do =)
thanks again
-Andy
Old 01-04-2004, 08:30 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: 351W pistons
keith black. very lightweight = more power.
about 200 bucks.
Mustangs are nice, but I'd rather have one of these...
Old 01-04-2004, 01:47 PM
Re: 351W pistons
thanks again
If you're going to have a custom set of pistons made I highly recommend CP pistons. Very light, VERY exact tolerances, and great customer service.
Compression height is the distance from the top of the piston to the first compression ring, deck height can mean either the distance from the crank centerline to the top of the bore on the block, or the distance from the top of the piston at TDC to the bottom of the cylinder head, including the headgasket, while torqued down.
351W carb into 351W FI Bootsgamer General Discussion 3 06-16-2012 05:36 PM
1987 F-250 351w Vacuum Hose Routing Ijustneedhelp F Series 0 07-04-2010 08:23 PM
what years had what brakes? 4 piston or 2 piston TEAM KLR '94 - '01 0 11-20-2003 04:30 PM
Single Piston Floating Calipers vs 4 Piston Non-Floating Calipers IOIOOI M3 0 02-09-2002 09:30 AM
