Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-03-2004, 06:26 PM
70camaro 70camaro is offline
Post OBDII fault codes
I have a 97 gmc 1/2 ton 4x4 with 100k miles. A few days ago my SES light came on. I have NOT noticed any problems. I am fairly capable under the hood, but have never had to work on my newer vehicles. So, I bought a scan tool to retrieve the dtc's. I got P1406 and P1300. The code definitions are very general, and I dont know where to start. Is there a manual or book or internet resource that will explain these IN DETAIL??? I dont want to just start replacing parts, I already spent 300+ for the scanner!!
Old 01-04-2004, 07:37 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: OBDII fault codes
The 1406 code is for the EGR performance...there is a bulletin #76-64-04 that covers a calibration update for that.
The 1300 code...there are some 1300 series codes..it all depends on the last 2 digits as to what is at fault...there is no 1300 code.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 01-04-2004, 08:05 AM
The scanner says "P1300 Ignition Control Module (Igniter) Circuit" No #'s after, just straight P1300.
I'm guessing the update needs to be performed by the dealer? Do you know of a resource that will give detailed info about the dtc's?
Old 01-05-2004, 05:03 PM
I ran a few checks on the EGR > checked for 5volts from PCM= good. checked for resistance in EGR solenoid= none. checked for resistance in EGR sensor= 4.40 on the 20k scale. Is this a good reading?? My guess is this is how the PCM knows how far the EGR is open, but I don't know what the parameters are. This reading was taken with the engine off, and cold. Bad sensor? probably not. Stuck EGR/carbon buildup? maybe. Does the calibration update loosen the tolerances on the EGR performance??? Removal and cleaning sounds like a good start... What do you think Merlin?
Still no clue what P1300 is...
OBDI/OBDII/CAN Code Readers Brian R. How-to | Technical Info 21 06-30-2006 04:59 PM
OBDI/OBDII/CAN Code Readers Brian R. Camry/Camry Hybrid/Vista 8 06-29-2006 02:38 PM
OBDII Trouble codes pallyo Grand Prix 3 01-29-2006 06:49 PM
OBDII Evap Code trouble RedDragon51 Grand Prix 1 01-13-2006 11:06 AM
OBDII Trouble Code Meaning? rocketpowered Aurora 5 10-29-2005 01:49 AM
