Old 01-03-2004, 04:23 PM
Steve99 Steve99 is offline
Send a message via AIM to Steve99 Send a message via Yahoo to Steve99
Keyless Entry
I have a 99 Eclipse RS and I was curious about keyless entry on whether or not it came stock on them. I bought it used so I did not get the keyless entry remote. I was hoping to get some help from some one on whether or not it was even possible for it to have keyless entry. If possible how do I program. I am new to the foreign cars so don't know as much about them. I would appreciate any and all help you guys can give me.
Old 01-03-2004, 06:01 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Unless someone tells you how to look for one installed, you can have the dealership look at it (don't let them charge you, i doubt they will try) since you have to get a new remote anyway (100-150 dollars new) or I think you can get a used one and program it. Again the dealership knows how. Someone here MIGHT know, but i'm not certain.
Old 01-03-2004, 06:25 PM
Re: Keyless Entry
See the thing is I have a remote I just need to know how to reprogram and were to look to reprogram it.
Old 04-24-2004, 06:57 PM
thepartsyouneed's Avatar
thepartsyouneed thepartsyouneed is offline
Banned
Re: Keyless Entry
To reprogram your keyless entry system for a new key fob:
1) Turn ignition to OFF.
2) Ground pin 1 of the Data Link Connector (black 16-pin connector under dash driver's side). Pin 4 of this connector is a ground, so placing a jumper wire between pins 1 & 4 will accomplish this. Grounding pin 1 tells the system you are getting ready to reprogram it.
3) Close all the doors.
4) Turn the key to ACC, then back to OFF. The power locks will lock/unlock. The system is now ready to be programmed.
5) Press a button on your key fob.
6) If you have two key fobs, press a button on the second fob within 1 minute of pressing a button on the first one. Both must be programmed at the same time. If you only have one remote, press a button on it 2 more times to signal that you only have one.
7) The doors will lock/unlock to signal that the codes were received.
8) Remove the connection between pins 1 & 4.
Old 10-17-2004, 12:17 PM
Flipz Flipz is offline
Hi,
This might be a stupid question but I am going to ask it anyway because I am not sure:
1. Where could I find a jumper wire - is a regular one or a special one that I need to get?
2. If for some reason the jumper wire does not ground the pins right could this mess up my electrical system and damage the power options? I see all the other steps are off that system - the doors, the remote etc. - or not grounding it right will just not allow the system to run in program mode for me to install the remote?
Thank you in advance and I will be looking forward to hearing from you.
Svetlin
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
