Old 01-03-2004, 03:27 PM
cherns24 cherns24 is offline
Angry changing serpentine belt
Can anybody tell me how to change the serpentine belt on my 2001 chevy blazer. It has A/C also. I bought the belt, the guy told me it would take 5 minutes. He was slightly off. Any help would be greatly appreciated.
Jason
Old 01-03-2004, 05:29 PM
airforceone's Avatar
airforceone airforceone is offline
Send a message via AIM to airforceone
It's really a 7 minute job. Do you have the belt removal tool???
The world's greatest Air Force...well, at least we blow up the most stuff.
Old 01-03-2004, 05:51 PM
RockyZ RockyZ is offline
Re: changing serpentine belt
Jason
I assume it is a 4.3 engine. You merely take a 3/8th inch ratchet and insert it in the belt tensioner hole in the tensioner and relieve the tension and slide the old belt off of the idle pulley to the right of the alternator. Remove the belt and reverse the procedure for installation. I have a 2000 blazer and that is the way I did it. There is usually a diagram on the top of the radiator support. The belt is easier to install if you route it on evertthing except for that same idle pully and again relieve the tension and slip over the pully. Remember to remove the ratchet! Good luck.
