Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-03-2004, 08:04 AM
hiio hiio is offline
electrical
I do not have a key for my trunk and have been using the electric trunk button in the car for years. Now it is not working and I'm baffled. Is it a fuse or a loose wire under the dash? Need help!
Old 01-04-2004, 09:25 AM
trendar trendar is offline
Re: electrical
First thing to check would be the fuse, but the trunk release motor on mine was sticking, and I opened it up to find the shaft of the nylon helical gear was worn down a bit, causing extra friction. I was able to fix it by putting in a couple of tiny washers, to allow it to spin freely again. It's fairly simple to remove and disassemble, provided you can get back into the trunk...
Old 01-09-2004, 06:29 PM
ziffdine ziffdine is offline
i think the door key is the same as the trunk key. that's how it is on my '82. did you change out your lock cylinders and lose the key?
Old 01-14-2004, 10:09 AM
burnM's Avatar
burnM burnM is offline
Re: electrical
Is the car ex-RCMP?I've got the same problem with mine.If you can fix it,please post how you did it.
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 01-29-2004, 10:51 AM
Re: electrical
found the problem after a locksmith installed a new lock for the trunk. It was a dislodged wire leading in the trunk just beyond the back seat. Damn simple problem, but I still needed a locksmith to get in.
