Old 01-03-2004, 02:51 AM
civicracer388 civicracer388 is offline
aftermarket tach!!!
just got a 88 civic hb. need to install a tach in it but i cant find the wire to plug the tach into. any help would be greatly apreciated.
Old 01-03-2004, 02:53 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: aftermarket tach!!!
plugs into your distrubiter onto the min plug if i am correct...but remember tachs dont add horsepower...hehe
Old 01-03-2004, 02:05 PM
vesper's Avatar
vesper vesper is offline
Send a message via AIM to vesper
i just did this 4 days ago. take you gluster out on the plug on the left theres a blue/silver wire tap that for the dizzy connection. then take apart the center console and the plug going from the ash try light and lighter has 4 wires use the black one for the ground the red one for the ignition 12+ and the white for the dash light. the red and white might be the other way around not to sure but it is def those 2. good luck
Old 01-03-2004, 02:39 PM
BullShifter's Avatar
Re: Re: aftermarket tach!!!
You could connect the tach signal wire to the ign. coil(-) but why run wires through the fire wall if you don't have to. Running the signal wire to the OEM signal behind the guage cluster, looks a whole "cleaner"
http://www.westworld.com/~joe_r/tach/tachinst.html - how to install tach
Old 01-04-2004, 12:15 AM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Thanks jackasssi I didn't want to have to post that site again.
Check out my car here My 91 Hatch
Old 01-04-2004, 04:37 PM
thanks guys for the replies!
