Old 01-03-2004, 01:35 AM
Toddr603 Toddr603 is offline
Unhappy 1997 Blazer ignition trouble
I have a problem I need help with, I pulled in the driveway in my blazer turned the blazer off and went inside the house. The next morning I went out to start the car and the key would not turn over the ignition remained locked. I tried jacking the front of the blazer up and moving the tires back and forth while turning the ignition, but it still wouldn't move. Please help I cant get the blazer out of my driveway and it's blocking my truck in the garage.
Old 01-03-2004, 01:57 AM
97blazerct's Avatar
97blazerct 97blazerct is offline
Send a message via AIM to 97blazerct
did you try to trun the key back to acc and move the wheel side to side?
make sure its all the way in park? good luck
fords.. drive a chevy
My 1997 Chevrolet Blazer LS 4x4:
http://www.sounddomain.com/id/chevy4x4girl
Check out the pictures of her! Sign the guestbook and rate her good!
Old 01-03-2004, 10:43 PM
1997 Blazer
I have tried about everything. The ignitions switch is stuck in the lock position it wont move to the acc position. Any other suggestions.
Old 01-04-2004, 08:48 AM
veeeee veeeee is offline
Unhappy ignition trouble
my ignition on my 98 safai is stuck and I cant get key to turn I was told I have to play with it till the keys turns and then replace the switch...but how do you replace the switch?
Old 01-04-2004, 05:35 PM
N2planes N2planes is offline
Re: 1997 Blazer ignition trouble
Well if all fails pop the lock with a screwdriver and then start the truck, GM made it easy to do.
Has the key been damaged< turning the steering wheel didnt help<
You can take the steering wheel off and manually unlock it.
the issue is there is a problem with the lock pins or to much tension on the lock hub.
Old 01-04-2004, 10:54 PM
1997 blazer
I bought a haynes manual to see if it could help me. I t suggested replacing the lock cylinder, the problem is you have to take the steering wheel off. In order to get the steering wheel off the chevrolet in the center part of the wheel has to be vertical 12-6 bosition, and presently it is stuck in the 2 and 7 position. Any other suggestions would be greatly appreciated.
