Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 01-03-2004, 12:17 AM
CraniumDesigns's Avatar
CraniumDesigns CraniumDesigns is offline
Send a message via AIM to CraniumDesigns
headlights dont work, but highs do?
Ok. I have xenon blubs in my civic's headlights. for some reason the regular headlights dont work, but when i put the high beams on they do. do they have 2 different filaments or is something wrong? note: they went out about a week apart from each other. this is the 2nd time my xenons have burnt out. should i just spend the extra money and get some nice PIAA ones or something. i got some generic ones. i guess you get what you pay for.
Steve Davis
AF Bay Area Crew
WEB DESIGNER!
www.craniumdesigns.com
Old 01-03-2004, 12:20 AM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
you can blow the lows without blowing the highs, you'll need new bulbs to fix it. If you're blowing them left and right there's something wrong.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 01-03-2004, 02:52 PM
Silverbolt Silverbolt is offline
Exterior Guy
Send a message via AIM to Silverbolt
Agreed...
If they're blowing out alot, you might want to check your wiring for anything loose that would cause a short... or check to see if moisture is building up in the housing.
"Take your time, do it right, and NEVER settle for less."
"The only stupid question, is the question not asked."
Old 01-04-2004, 03:15 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
There is NO fix to prevent this from happening other than just using stock wattage bulbs, or getting one of those expensive H4 harness/wire upgrade kits. Plain and simple, the factory headlight wiring and harnesses CANNOT support the higher wattage of 80,90, or 100 watt headlight bulbs, and therefore any pair of such you get WILL blow out way more sooner than they normally should if not cause any electical problems or melting of headlight housing insides or harnesses. This price one has to pay to "look cool" or pretend they have HIDs. Just get some stock wattage PIAA bulbs, or some Sylvania Silver Stars and they will still look great, and you won't have to worry about them blowing out on you every few months.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 01-05-2004, 08:32 AM
QuakeWork120 QuakeWork120 is offline
Send a message via AIM to QuakeWork120
Make sure that when you put the bulbs in, you are not touching the glass. When running, the glass gets extremely hot. The oil from your fingers gets on the glass, heats up and causes the bulb to blow.
1997 Acura Integra GS-R
-AEM CAI
