Old 01-03-2004, 12:00 AM
David_ David_ is offline
running out of paint
ok, if i was painting a model, using the can a second time, and i run out.
do i continue painting after i buy new can (old paint would have dried)
or do i strip it all and start again?
(assuming the paint is only on one side, or on front bumper only)
edit: how thick should i lay on primer? about 2 coats? three coats? or just a light covering?, and how long should a can of primer last (tamiya)... alot longer than the sprays?
Old 01-03-2004, 12:57 AM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Look in the FAQ, shows you everything in there about how to spray primer and so on...
Old 01-03-2004, 06:45 AM
Re: running out of paint
yea.... doesn't tell me what to do in case i run out of paint, i looked there...
Old 01-03-2004, 01:05 PM
simdel1's Avatar
simdel1 simdel1 is offline
if you just about managed to get a full coat before it packed up then you should be ok. but if there is a deffinate place where you can say "thats where its ended, look its a totally different colour" then it might be worth while stripping and starting again. of course its also worth sanding the old coat a bit before you apply the new....
erm, in my slightly drunken state though i would wait for some replies from more experienced modelers before you follow mine...
simon, in portugal on holiday
Simon
Old 01-03-2004, 01:44 PM
SonyMobile's Avatar
SonyMobile SonyMobile is offline
Send a message via AIM to SonyMobile Send a message via Yahoo to SonyMobile
If its a light coat, you should be able to just paint the whole thing over the old coat with the new can, but if it is a relatively heavy coat i would suggest stripping or sanding the paint off, but just try painting over the old stuff first
Old 01-03-2004, 09:36 PM
oh ok, thanks for the help...
and also, i heard that caustic soda won't remove lacquer (automotive paint) is that true? coz my lhs said it'd remove any paint... so im confused.....
