Old 01-02-2004, 09:15 PM
J_Spec_NiTeMaRe's Avatar
J_Spec_NiTeMaRe J_Spec_NiTeMaRe is offline
Send a message via AIM to J_Spec_NiTeMaRe
383 stroker?
hello everyone
my friend has a 5.0 late model mustang, and he was wondering if its possible to use this stroker kit for it, or do you have to have a 351w to use it? thanks.
Old 01-02-2004, 11:57 PM
boosted331 boosted331 is offline
Read the auction. 351's only.
Old 01-03-2004, 12:04 AM
SIKCRX SIKCRX is offline
Re: 383 stroker?
is it me or is it always "a friend" that wants/needs/has something.
Old 01-03-2004, 03:18 AM
yeah i read the auction, but it confused me because the title said "mustang 5.0." im not versed on fords, as you can tell. and yes, it is my friend that has the mustang. we found another kit that is actually for the 302, to stroke it to a 331. he wants to eventually supercharge it, but it has 166,xxx miles on it. we thought that building the bottom end would be a good starting place, can anyone offer other ideas?
Old 01-03-2004, 03:34 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
331 is a very good kit for the 302, best IMO.
If he want to boost, do not go above 9.5CR.
The VE is fairly low is a pushrod engine, but you do not want to push it.
www.turbofast.com.au/TFcompB.html
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 01-03-2004, 08:49 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: 383 stroker?
347 is also a good choice. Unless you relly bore out the cylinders, the piston to wall stress will not be much of an issue, so go for the higher CI, and more torque.
you can still boost a 347, as long as the pistons are dished for lower comp.
or you can use heads with a larger Chamber.
Mustangs are nice, but I'd rather have one of these...
Old 01-05-2004, 12:26 AM
thanks everyone
he decided to get the 331* kit as well as GT40P heads.
i know its a newbie question, but can anyone tell me if a 302 will directly bolt in a 6 cylinder mustang (1994-2002 models)? thanks.
Old 01-05-2004, 06:49 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: 383 stroker?
He's going to spend the money to run a 331 stroker, but only use the P heads? Why??
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-05-2004, 08:50 AM
SkylineUSA's Avatar
I am with Hiflow
There are a lot better heads. Why bottle neck the engine? What intake?
I am pretty sure, motor mounts will need to be changed.
AFR 185s, would be very nice for that engine.
Old 01-05-2004, 09:54 AM
Re: 383 stroker?
Almost anything is better than the old-as-dirt gt 40's.
but maybe he's on a budget or something.
as far as the bolt on goes, yeah, you need a new motor mount kit, possibly a k-member and dpending on the tranny, a new bellhousing.
Old 01-05-2004, 01:29 PM
HiFlow5 0's Avatar
Stanger
Re: Re: 383 stroker?
Only thing I would really suggest is stonger or better motor mouts then the stock ones. Since the 331 uses the same exact block as a 302, then everything else will work just fine.
-2013 Ford Flex
-1999 Ford F150
Old 01-05-2004, 01:41 PM
Re: 383 stroker?
but he said he was bolting it into a v6.
and a 96-02 model at that.
I doubt the old 302 will be a direct fit.
Old 01-05-2004, 02:25 PM
HiFlow5 0's Avatar
Stanger
Re: 383 stroker?
Hum, I must have missed that part. Although he didn't specifically say it was for a 94-02, just asked if it would fit.
-2013 Ford Flex
-1999 Ford F150
Old 01-05-2004, 03:22 PM
thanks for all your info, but i gotta clarify some things.
My friend who has the 95 GT, is purchasing the 331 stroker. We both don't know anyone at all who knows anything about Fords, so we made the mistake of listening to the idiot at Pep Boys who told us that the GT40p heads are really good. Judging from your responses, that's not the case. We listened to SkylineUSA and looked up the AFR heads, and he said that he will probably purchase those after he gets paid.
The question about putting in a GT engine into a 6cyl is completley independant of his situation. I just wondered if it were possible. So if one were to do that, they would need obviously the motor and tranny, and engine mounts, crossmember, and bell housing? And thats all?
thanks.
Old 01-05-2004, 04:39 PM
HiFlow5 0's Avatar
Stanger
Re: 383 stroker?
Look closely at the AFR 185's, the pistons might need to be notched so you don't mangle the valves.
-2013 Ford Flex
-1999 Ford F150
