Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-02-2004, 07:19 PM
Lwop Lwop is offline
Electric Window problem 95 Rodeo
The electric windows on my wife's 95 Rodeo just stopped working. I checked the 30 amp fuse and it is ok. I also checked and have voltage to the hot side of the fuse slot. I opened up the drivers door panel and could not find any loose conections. Anyone have any idea what I should try next? All four windows do not work.
Thanks.
Old 01-03-2004, 05:50 AM
rodeo02 rodeo02 is offline
Sounds like it's gotta be at the switch panel. Pop the driver's door switch panel out, clean it up & check for good contact(s). These take a beating over time, get wet with rain water, etc.. G/luck
Joel
Old 01-04-2004, 04:53 PM
Re: Electric Window problem 95 Rodeo
I checked the switch and all there looked ok. I am not getting power to the switch though. It is nearly impossible to follow the wiring from the fuse box to the door panel. Anyone know if there are any connections between the two? I can't imagine the problem being a broken wire.
Thanx, LWOP
Old 08-26-2004, 06:22 PM
Genaro808 Genaro808 is offline
I'm having the exact same problem; were you able to figure it out? Any help is appreciated.
Old 08-26-2004, 06:27 PM
BTW, what is the fuse labeled as on the fuse box?
THX!
Old 12-26-2004, 01:35 PM
stickman10 stickman10 is offline
I just encountered this same problem with all my windows refusing to work (as well as my sunroof) on my 96 Rodeo. Any answers to the above concerns would be appreciated! Thanks.
