Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-02-2004, 07:18 PM
huntinhard huntinhard is offline
horn problems
Hello fellow truck owners, my horn is not working on my truck I have checked all the fuses including the horn circuit under the hood I have also pulled out the horn relay and tested that also I tried looking for a possible ground problem and have found none. the next is to pull the horn for testing does anyone have any other suggestions. Thanks in advance for your input.
Old 07-24-2004, 01:33 AM
rajjhauf rajjhauf is offline
Re: horn problems
My 97 Ram did the same thing, except it would blow a fuse after you honked the horn for about 2 seconds. I found that my horns were shorted out and after replacing them i've never had any more problems. (took a while to figure this out)
Old 09-15-2005, 07:56 AM
rogerh rogerh is offline
Re: horn problems
Hi. I'm not sure my horn ever worked and can't even find the fuse for it. Did you fix your problem, and can you help with mine?
rogerh
Old 09-18-2005, 06:51 PM
dtstrout dtstrout is offline
Re: Re: horn problems
Mine was out also. After checking the fuse and hearing that the horn relay (located on the drivers side under the hood) was working, (you can hear it click when you press the horn button) I checked for voltage at the horns. Since there was, I replaced the horns. $10 at a junk yard and an easy swap.
Old 09-18-2005, 10:19 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Re: horn problems
Sounds like an excuse to buy some air horns
Pictures of the Truck
