Old 01-02-2004, 06:52 PM
mzauss mzauss is offline
electrocal problem with 97 buick park avenue
Was driving when the dome light came on and went off and the drivers side window started to come down. Heard the door locks klick. It was raining at the time and car was running just fine. I did happen to get the window closed by pushing on the up window switch over and over again. Still the window wanted to come down after a few moments. When I got home I shut the car down and later came out to find the door locks will not work and the windows do not work. Using the remote the drivers side door opens and closes. The dome light and car does start and will run ok. All other electrical exuiptment seems to work ok.
Any help before I take it for repair? Seems like it will have to go back to a factory outlet to be fixed unless I fine out otherwise.
Thanks for any HELP...
Old 01-02-2004, 10:58 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: electrocal problem with 97 buick park avenue
I would check the central ground for the driver's door. I would also inspect the wires in the door boot.
