Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 01-02-2004, 04:44 PM
the4bones the4bones is offline
1994 pathfinder power/stall problem
my 94 pathy has had a decrease in power with a rough idle. I thought it may be clogged injectors or fuel filter so I have replaced it and added a can of bk injector cleaner to the last tank of gas. It seems better but still is not consistant. Any ideas? Timing belt has allready been replaced also.
Old 01-03-2004, 11:01 PM
Gurgus Gurgus is offline
Re: 1994 pathfinder power/stall problem
I been going through the same thing with my 95.
Change your air filter and your oxygen sensor. This sounds like it would be the O2 sensor.
Old 04-28-2004, 01:27 PM
William Davis Jr William Davis Jr is offline
Re: Re: 1994 pathfinder power/stall problem
Try the wire right by the air filter move it around see if the idle pick up if so go to junk yard get another one dosen't matter what make the car is as long as the connecter is the same I think the wire s are black& white
Old 04-28-2004, 11:39 PM
mkz mkz is offline
plugs?
Old 05-17-2004, 06:03 PM
nissanboy nissanboy is offline
Re: Loss of power & stalling
Check out you Mass Air Flow Meter & the harness connected to it, wiggle it around. This located between yor air filter & your throttle body.
96 Cavalier won't start/stalls when boosted xcooneyx Cavalier Problem Diagnosis 0 01-15-2011 01:03 AM
1994 ZJ Power Steering Problems Jeep Grand Cherokee snofellow2003 Grand Cherokee | Grand Cherokee SRT8 4 09-08-2010 11:39 AM
1994 JGCL Power Seat problems On the Right Grand Cherokee | Grand Cherokee SRT8 1 01-07-2007 02:52 AM
1994 Pontiac Bonneville Stalling Problems Sixstringax Bonneville 5 10-01-2006 11:14 PM
1994 ZJ Power Steering Problems Jeep Grand Cherokee snofellow2003 Grand Cherokee | Grand Cherokee SRT8 4 10-21-2004 11:13 AM
