Old 01-02-2004, 03:37 PM
silviaracer silviaracer is offline
Send a message via AIM to silviaracer Send a message via Yahoo to silviaracer
any way to turbo a 3000gt n/a
my friend has a 3000gt non-turbo and he wants to turbo it. do they make a turbo kit for the non-turbo 3000gT??? or would he have to swap the turbo motor in?
please help me out with this i know very little about the 3000gt
thanks
Old 01-03-2004, 05:26 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
you dont have to do a full motor swap, but you can pull the turbo stuff off of a vr4 and put it on an SL
Old 01-03-2004, 05:36 PM
TriPocalypse666 TriPocalypse666 is offline
what about.....
what about greedys bolt on turbo for the non turbo 3000gt's....can you put that on it tal?
Old 01-04-2004, 10:20 PM
Re: what about.....
I didnt know greddy made a turbo kit for the non turbo cars, if they do it should work.
Old 01-05-2004, 01:35 PM
well im not exactly sure if they were specially designed for the n/a 3000gt....above the picture and product listed for i it says its really hard to make a n/a car fast....slapp these turbos on bla bla bla.....so im guessin its for the n/a 3000gt's......but i would check it out....it seems every product that is made for the 3000gt is made for the vr-4's kinda leave out the n/a guys....heres the website where you can find all the turbos.....tal check it out and tell me what ya think
www.horsepowerfreaks.com
Old 01-05-2004, 06:02 PM
That part number is for a set of 13g turbos, and will only work on a TT model. They are direct replacements for the stock turbos.
Old 01-06-2004, 04:22 PM
Re: any way to turbo a 3000gt n/a
Thanks
Old 01-06-2004, 07:04 PM
well........
well doesnt it say in the description about the turbo that it is hard to make an n/a car go fast and that jive.........would the turbo also be for the base and sl models???
Old 01-07-2004, 02:38 AM
What you would get is the turbos only, so if you took the turbo parts off a vr4 then yes, they would be able to bolt up. the problem is that you will never get close to using the power of the stock turbos with 10:1 compression. if you put a vr4 engine in a base or sl then it would be benificial, but you would have one hell of a time putting all that power to the ground.
Old 01-07-2004, 05:39 PM
hhmmmm....
ok if thats the case then tal......how does the gst put the power to the floor being a front wheel drive car?.....and how would i change the compression from 10:1???..........how much would it cost to get a vr4 engine?
3 questions enclosed
Old 01-08-2004, 03:06 PM
you will be able to put the power to the groud just as well as a gst, I was refering to haveing 8:1 and 13g's. That will put you upwards of 400hp. From a roll you would dominate, but from a stop you would suck just as much as a modded gst. Most of the fast DSMs are AWD.
to change the compresion you just have to change the pistons
couple grand for the vr4 engine
Old 01-09-2004, 10:34 AM
Dunecomber Dunecomber is offline
3si.org
You should check out posts concerning this topic on 3si.org they have covered this extensively and many are willing to help in the process of this conversion. A couple of companies such as GroundZeroPerformance.com are attempting single turbo kits right now that will be cheaper and easier than any other option on the market. If you're ready to do this get ready to spend every paycheck for some time though. NA were not built for that power though so you're gonna have fun with all the parts that need to be installed. Just an example you need an LSD and the only ones available run 900-1000.
1994 Mitsubishi 3000GT
DNP Hard Intake Pipe, K&N FIPK, 97 Front Bumper, 97 Lifters, Gutted, Cat, Indiglo Gauges, Pioneer P840MP, Infity Kappa 693.5i, Infity Perfect 6.1 Component, Ground Control Adjustable Coil Overs
1999 Camaro (my little bros car... just getting started)
Panasonic HU
Old 01-10-2004, 10:06 PM
duchguy's Avatar
duchguy duchguy is offline
Send a message via Yahoo to duchguy
Tx
there r 2 NA's in texas with the turbo conversion. dzapata and mitsutogocars or something like that, check them out on 3Si.org and ask them the questions.\
good luck!!
Should I turbo It??? 3000gt95 3000GT/Stealth 10 12-18-2009 10:21 AM
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 04:49 PM
is there any way to make ur gst spyder faster with out buying any parts? SPYDERGST97 Engine, Transmission and Drivetrain 31 04-14-2005 05:53 AM
Any sites with 3000GT interior and performance parts? GTO4Life 3000GT/Stealth 7 02-26-2004 06:21 AM
