Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-02-2004, 08:11 AM
kilpatty43's Avatar
kilpatty43 kilpatty43 is offline
Send a message via AIM to kilpatty43
lowering springs
im finally getting some springs for my car and im looking at eibach pro kit or skunk2 springs...any recommendations on which would be best for my teg?
"your friend is the person you can call to bail you out of jail...your best friend is the person sitting next to you saying, that was ****ing awesome!!!"
Corvette~The only sports car that matters
Old 01-02-2004, 12:45 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
Eibachs are nice. I only usually hear about skunk2s suspension dept. when its in reference to their coilovers. Id stick with the suspension only company
Old 01-02-2004, 08:09 PM
integratool666 integratool666 is offline
Re: lowering springs
i think eibachs are one of the best - my friend has them - and he can take any turn any time - in my opinion - those are probably the best you can get
Old 01-02-2004, 10:17 PM
shaunthebadass shaunthebadass is offline
Send a message via AIM to shaunthebadass
my friend has the eibach pro kit on his spec-v and those are pretty cool, they were definately made for taking corners REALLY fast. i have neuspeed race springs on my dc2 integra and i love them. when they settled and everything was said and done they were at almost a 3" drop in the front and 2.75" in the back. i threw 17's on there with 205/40's and it looks very good. there is no wheel gap and they dont rub. if your're looking for cornering and stiff suspension.....go with the eibach; if you want looks and almost as good suspension....go with the neuspeed.
the eibach's usually run for $185
the neuspeed race is usually $130-150
Old 01-03-2004, 02:02 AM
BullShifter's Avatar
If I had the choice, I'd pick the Pro Kit. They're nice all-around springs when combined with good struts. H&R's are cheaper than Eibach's & perform as well or better than the Pro Kit. If your looking for improved handling, after (1) tires, (2/3) struts/shocks, & (2/3) springs, A rear sway bar upgrade will have the greatest afftect.
1 2 3 - order of importance for improved handling.
Old 01-03-2004, 11:37 AM
HondaIntegraXSI HondaIntegraXSI is offline
Send a message via AIM to HondaIntegraXSI
The skunk 2 will ride rough as hell, and eibach is a good ride but still a little rough. IMO save you money and get some Koni struts with Neuspeed Sport springs. this will eliminate will gap, is driver friendly by adjusting to the road conditions, were designed to work in corespondance, and are a firm yet smooth ride. and If you want performance you go with 1)tires 2)bushings 3)swaybars 4)strutbars 5)struts/springs
Old 01-03-2004, 11:38 AM
oh, forgot, alignment is #2
Old 01-03-2004, 01:41 PM
Re: Re: lowering springs
I disagree with the "strutbars" being before shocks/springs, those should come LAST! Since their biggest improvement is looks even top of the line functional parts.
Old 01-03-2004, 02:03 PM
looks?? The last thing I want is a big-ass bar across my motor bay.... it prvents chasse flex under hard cornering, which happens from body sway. which you eliminate with springs so to get the most of your suspention, you should prevent chasse flex before swaping springs.
Old 01-03-2004, 02:59 PM
There is no need to try an educate me on suspension. . .Strut/tie bars stiffen the car a little, sways bars control body sway(roll). They are 2 completely different things, 1 provides stiffness & the other provides roll control. By the law of physics, FWD has understeer(slow/bad) as a natural characteristic. No tie bar will create oversteer to make it neutral or slight bit of oversteer(great for autocross) only a larger rear sway & stiffer springs/struts can do this. The lowered CG also helps. Suspension isn't anything without the right tires.
Old 01-03-2004, 03:10 PM
Tegryder11's Avatar
Tegryder11 Tegryder11 is offline
Send a message via AIM to Tegryder11
I say go for the Eibach sportlines, you will most likely not have to get a camber kit. I'd stay away from coilovers if thats what your talking about if you get the Skunk2's. My friend has a teg just like mine and has Skun2 coils and the ride is hella bumpy, not smooth and just overall shitty stick with the Eibach's homie.
<--- JDM Pose Foo
2000 Acura Integra GS / 16" Focal Wheels / Toyo Tires /
Alpine Audio System / H&R Sports / KYB AGX's / AEM Short Ram
Old 01-03-2004, 08:50 PM
GiRlieGrLB18c1 GiRlieGrLB18c1 is offline
Send a message via AIM to GiRlieGrLB18c1
FiRst off---What kind of ride do you want? How much loweR do you want to be? You gotta think about aftermarket shocks too...
*I had Eibachs on my old car~no complaints niCe and stiff w/KYB's dropped about 1.5 inches
*Now i have Neuspeed Race springs~no aftermarket shocks yet (spring 04' WHOO-HOO) My ridE is slAmmed...LOL
Old 01-03-2004, 09:10 PM
I say swaybars, bushings, tires, and alignment and nothing else. Springs as the first upgrade is like running 25 psi on stock gaskets and internals. It's just not smart, and your performance will suffer if you don't do the little things...
Springs Made in Canada springman West Canada 0 12-01-2010 03:14 PM
Lowering Spring HELP! sentoyang Brakes and Suspension 2 10-23-2009 04:34 PM
lowering springs and front/back springs?? ynii_g Camry/Camry Hybrid/Vista 4 05-30-2004 12:28 PM
Ground Control adjustable springs VS. lowering springs AznDragon Tires and Wheels 3 02-17-2002 05:21 PM
