Old 01-02-2004, 02:28 AM
Crx90SiRicer Crx90SiRicer is offline
Banned
ls/vtec vs b16b
Hi ..the ls/vtec is about 200 hp and the b16b is also around 200 hp and which is the good one>? isn't that the b16b(type r) is more expensive?
Old 01-02-2004, 12:26 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: ls/vtec vs b16b
I have yet to see an intelligent post by you.
I'll help you out nonetheless... You can't go buy an LS/vtec off any online sites, it's not a stock Honda engine. It's an LS block with a b16 or b18 vtec head, and you have to custom build one. Yes they can reach about 180-200hp, but are a bitch to do. My b16b cost $4,450 with shipping. I'd say an LS block and let's say a b18c5 head will cost about $2,500 or so. That' s just for the engine.. then you have to get it tuned, get the two parts working together, and pull all your hair out because you spent all that time/money and you can't even rev to 7k rpms without things breaking. So you go buy new rods and higher compression pistons, and your r/s ratio still sucks but you can rev a bit higher. If tuned well, I'd say the total cost for 200 reliable hp would be a little bit less than the b16b, unless you know a mechanic who will hook you up. Me, I kinda like having an engine already factory-tuned and am willing to spend the extra buck for reliability. B16B's come with 185hp btw, but with a few bolt-ons 200hp isn't a hard goal to reach.
Old 01-03-2004, 05:21 AM
Banned
Re: ls/vtec vs b16b
that is what i was talkign about..it's already built.so the ls/vtec is more stronger and lesseR? thanks Ricochet
Old 01-03-2004, 09:41 AM
NOBU-SAN NOBU-SAN is offline
Re: ls/vtec vs b16b
Not quite built. the b16b is, but the ls needs too much TLC to be very user friendly. In theory, the ls/ vtec is hot, but most of us are looking for a drop in type of swap. Already "built" engines are factory engines. Built meaning they run fine without the headache of having them tuned and making them(Heads and blocks) work together.
1998 Civic EX 2dr MT :Koni RSK suspension, ST 19mm Rear Sway Bar, Hawk brake pads, Civic Hybrid wheels(No bullshit), C- West style front bumper, Apexi N1 cat back, AEM cold air, LSR short shifter... more to come!!! Holler back.
2006 SV650: M4 carbon high mount, racetech springs & oil up front, seat cowl, suzuki frame sliders, new shock coming soon......
Old 01-03-2004, 06:05 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
If you know for a fact(which can be hard) it'll be done right, since you already said you're not gonna do it, then get the LS/VTEC. The extra displacement may come in handy.
Old 01-06-2004, 12:49 PM
93integra:ls/vtec 93integra:ls/vtec is offline
if have a gsr head i need a gsr throttle cable for my ls/vtec
Old 01-15-2004, 10:44 PM
redleaf786 redleaf786 is offline
Re: ls/vtec vs b16b
the non vtec honda blocks have extra low end torque then their vtec counterparts to make up for not havin a vtec but when u get a vtec head on the ls ull have the high end too, the ls block has more low end then the b16, but there is a nother prob too... by usin a gsr head on the block the rods tend to spin, wat i did on my integra is put a jdm b16 vtec and shot peened the ls rods and they wont spin that way, i put some jdm b16 pistons in my ls and got some type-r cams, and i do my own head work, im runni mid to low 13s but my compression is real high at about 11.5... this NA isnt as safe as ppl say
Old 01-16-2004, 01:41 PM
jdmcrxhatch jdmcrxhatch is offline
Send a message via AIM to jdmcrxhatch Send a message via Yahoo to jdmcrxhatch
Re: ls/vtec vs b16b
yeah but for the ls/vtec swap could be expensive because the bottom of the block isnt strong enough and could blow right or something like that...?
I am asian i have enough rice in my basement i dont need anymore on the street.
JDM YO w00t w00t.
about domestics
Stroked LS Vtec (2.2) vs b20 vtec vs h22 Twyzz Let's get Technical! 3 05-22-2004 08:55 AM
What should I expect to run in a stock ls-vtec? And also a cr-vtec? sheemo3 Engineering/ Technical 0 09-08-2003 03:30 PM
What should I expect to run in a stock ls-vtec? And also a cr-vtec? sheemo3 Engineering/ Technical 0 09-08-2003 03:29 PM
LS with turbo, or LS with LS/VTEC and Turbo IntegRocket32 Integra 3 10-11-2002 01:13 AM
ls/vtec how about a f22/vtec crazy_ss Engineering/ Technical 9 01-19-2002 11:32 PM
