Old 01-01-2004, 03:56 PM
scubatomm scubatomm is offline
Angry milky pink trans fluid, coolant low
99 plymouth voyager w/ 75k miles 4cyl auto., suddenly the van overheated and spewed pink milky stuff all over, found the trans fluid to be milky, but also the coolant is low and the radiator has the pink milky stuff in it too. I'm thinking the trans cooler tubing or whatever that passes thru the radiator must have sprung a leak, broke off? etc. Has anyone ever heard of this happening?? It's a new one on me after monking w/ cars for about 35 years. Thanks, Tom
Old 01-05-2004, 11:42 PM
tazman tazman is offline
It sounds like a water port in the head has blown through. That's where there is no visible leak until the head is remove and then you can see the channel cut in the gasket from water pressure. Did the same thing on 2 older Omni's I once owned. Check the head for warpage and then replace the head gasket provided the engine is still good.
Old 01-05-2004, 11:46 PM
Oops! Sorry. Should have read your post a little better. It is the rad trans cooling tube that has coroded or is defective and caused your leakage.
Old 02-03-2004, 10:22 AM
98JADENEON's Avatar
98JADENEON 98JADENEON is offline
Re: milky pink trans fluid, coolant low
Yep the same thing happen to a friends 99 2.4. the cooler in the radiator cracked and leaked. took the tranny out as well as the head gasket. total of about 4 grand to fix everything.
