Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-01-2004, 01:35 PM
Aurora01 Aurora01 is offline
Unhappy Steering Wheel Controls
Need help with controls on steering wheel of 2001 Aurora the controls don't all light up at night. Anyone know how to get at the switches? Do I have to remove the air bag? Help.
Old 01-01-2004, 09:21 PM
Bill V Bill V is offline
Re: Steering Wheel Controls
New style Aurora steering wheel controls are removed by prying the assembly (CAREFULLY!) from the wheel. The harness is VERY short.
Old 01-01-2004, 10:13 PM
auroradream's Avatar
auroradream auroradream is offline
Which controls don't light up on your wheel?
Old 01-02-2004, 10:03 AM
Re: Re: Steering Wheel Controls
Both radio and the temp controls the only one working is the fan speed selector
Old 01-03-2004, 12:34 PM
Of the 4 controls, only my 2 radio controls work. Guess I'll try pulling my climate switches out.
Old 01-03-2004, 12:56 PM
Indy8's Avatar
Indy8 Indy8 is offline
Are these controls powered through an old style friction plate on the backside of the wheel? If so, can the plate(ring) just need cleaned?
Quality isn't expensive, it's priceless.
Old 01-03-2004, 12:59 PM
I also wondered how the connection was made from column to wheel. But if it was a slip ring, I think my lights would flicker as I turned the wheel. My 2 radio lamps are work properly and the 2 HVAC lamps are always off.
Old 01-03-2004, 01:03 PM
Indy8's Avatar
So you don't know if the control switch is bad or it's just not getting power?
Old 01-03-2004, 01:14 PM
Hopefuly each switch has simply 2 terminals, and testing the leads will be easy. I don't have the FSM yet. I'll go out in a minute and check it. If you don't hear from me again, the airbag probably deployed and snapped my neck.
Old 01-03-2004, 01:23 PM
Indy8's Avatar
Ouch!!
Old 01-03-2004, 09:38 PM
bustedratchet bustedratchet is offline
Re: Re: Re: Steering Wheel Controls
No friction plate Indy, All that stuff runs through the clockspring.
Old 01-03-2004, 10:21 PM
Indy8's Avatar
Re: Re: Re: Re: Steering Wheel Controls
Thanks, I've got to get the FSM!
Old 10-15-2007, 01:15 PM
tyz tyz is offline
on my 2002 aurora, the radio, temp controls, fan speed selector on steering wheel & cruise control stopped working at the same time. Can't find fuse. I checked under the seat. how did you fix yours? thanks
