Old 01-01-2004, 12:11 PM
scb scb is offline
any Ford Service Techs out there?
96 sable, 121k, 3.0 engine, check eng. light, code reads "impeller speed sensor circuit malfunction". Need help in locating/replacing this sensor. Tranny shifts very hard from 1st into 2nd unless I accel very slow. Also, when shifting from park into drive, rpms increase from idle to about 12-1400 and trans slams into gear. I'm told this sensor measures the impeller (or input shaft) speed to determine engine speed, shift points, etc. Can I replace this one myself? Where exactly do I find it? Thank you in advance for any help...
Old 03-05-2004, 12:18 PM
Davie128 Davie128 is offline
Re: any Ford Service Techs out there?
Hi: Try front of engine by timing tab. Look for small black unit with wire coming out to a harness. Some real hard to see until you remove the drive belt. These sensor units must be aligned properly, so be careful and reposition carefully. Mark all these types of units prior to removale ( whiteout works good or a yellow paint ball pen) so you can reposition the new unit exactly.
Thanks,
Davie128
Any Honda Techs out there??? 99nosmax General Discussion 0 02-06-2006 08:44 PM
Any Honda Techs out there??? 99nosmax MDX | Pilot 0 02-06-2006 08:35 PM
Help...any tranny techs out there?????? roonie C/K 8 10-16-2005 03:56 PM
Any Crankshaft Techs out there? michelle g Trans Sport 1 08-11-2005 08:29 AM
is there any KA24DE turbo kits out there asiansk8er77 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 8 10-24-2003 02:15 PM
