Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 01-01-2004, 03:19 AM
redcharged redcharged is offline
piston interchangeability?
hi, i have a b5 engine, but it's pistons were damaged.
can i swap only the piston with another type of piston such as the one used in b6 engine since it has the same bore size (78mm) but different in stroke (B5 is 78,4mm & B6 is 83,6mm) ?
B5 : bore x stroke = 78mm x 78,4mm
total displacement = 1498 cc
compression ratio = 9.4
B6 : bore x stroke = 78mm x 83,6mm
total displacement = 1597 cc
what is the compression ratio for B6 engine?
have anyone done this?
i really need the info.
thanks a lot.
Old 02-13-2004, 03:22 AM
gtx510 gtx510 is offline
Re: piston interchangeability?
If the connecting rods are the same length and the wrist pin the same dia, yes.
Taurus Interchangable parts rlhoward59 Taurus | Taurus Wagon 3 11-17-2010 11:19 PM
Are pistons & rods interchangeable when rebuilding '95 3.8 engine? J Parks Bonneville 0 04-29-2010 09:32 PM
Can all metro transmission interchange? Are there different Gearings? Idaho_Mechanic1984 Metro 6 10-19-2009 05:14 AM
Transmission interchange...what years are interchangable? Tominator2000 Metro 1 03-14-2005 07:23 PM
