Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-31-2003, 10:19 PM
MN_REV-800 MN_REV-800 is offline
Towing and Overdrive
I'm new this message board. I didn't see any past threads on this.
At what towing weight do I need to turn off the overdrive? My rule of thumb in the past was if I noticed that it was shifting in and out of overdrive a lot, I would turn O/D off. Is this a good rule? I'm in the process of installing a transmission oil cooler. Does this allow me to use O/D since the temps should stay lower?
The only towing I do is an aluminum snowmobile trailer with one or two snowmobiles on it.
Heres the towing weight estimate:
Trailer and 1 snowmobile = 550 + 250 = 800 lbs
Trailer and 2 snowmobiles = 550 + 550 + 250 = 1050 lbs
Plus, two persons and their gear.
I will be towing from Minnesota to Montana later this month and would like to have the O/D on to keep the RPMs down while on the freeway at speeds of 70 to 75 mph.
Old 01-03-2004, 01:16 PM
sha_zapple's Avatar
sha_zapple sha_zapple is offline
Re: Towing and Overdrive
The 4Runner is GREAT with towing. We had a 20 foot fishing boat behind our 98 Limited, and you could barely tell it was there. Plus we had 5 people + gear.
Id keep it in overdrive most of the time especially if its on flat roads. Climbing hills if its shifthing in and out id turn it off, but even then I find the 4Runner to be very well designed for this.
Your 4Runner should be able to tow your trailer with no problem. Take it out for a test run.
