Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-31-2003, 08:57 PM
riceizyummy riceizyummy is offline
turbo question. HELPPP
okay, is it true, that you will get better acceleration off the line if your running a single turbo opposed to running a twin turbo, because a tt takes longer to spool up? i was discussing this with a friend and i thought id bring it up here to see if that is true.
Old 12-31-2003, 08:58 PM
454Casull 454Casull is offline
Re: turbo question. HELPPP
Hmmm... it's debatable. Personally, I think singles spool up faster.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 12-31-2003, 09:13 PM
so there is no deffiniate answer?
Old 01-02-2004, 10:22 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
twins spool up faster actually, because they are smaller.
the only thing that will give you better acceleration I beleive is more boost.
so if you have a twin setup that makes more overall boost than a single, you'll have more power, and if they are individually smaller than the single, they will spool faster.
Mustangs are nice, but I'd rather have one of these...
Old 01-02-2004, 08:00 PM
Smaller turbos have lower inertia, but in this case, the turbos in a twin setup have to run on half the amount of exhaust gas.
Old 01-03-2004, 08:25 AM
that depends on the engine type.
on an inline, yes.
on a V setup, no, they will each have equal exhaust. ex. a V8 twin setup will each get 4 cyl worth of exhaust, but an inline 4 single turbo will have 4 cyl of exhaust too.
granted, thi depends on the size of the engine as well.
It's complicated, but to put it simply, the twin setup will spool faster.
I don't know of any twin turbo inline 4 setups.
Old 01-03-2004, 11:55 AM
What are you talking about? I was mentioning the difference between single/twin turbo setups. Why would you think I would talking about usage on different engines?
Old 01-04-2004, 07:16 AM
well, on a dual exhaust V8, how would a single turbo get all the exhast from the engine?
That's why I thought that a twin setup would be good, one for each header.
sorry.
Old 01-04-2004, 12:01 PM
johnnyBgood johnnyBgood is offline
Send a message via AIM to johnnyBgood
You run the turbo off the merge pipe.
Old 01-04-2004, 12:20 PM
Yes. Although it's not very practical - sorry, as practical as one turbine per bank.
Old 01-04-2004, 11:06 PM
Right. But you could run a massive turbo (T88 for example) with lots of boost and get almost instantaneous response.
Or go even bigger and get the biggest turbo I have heard of the street, the T-105, and just go all balls out. You may get some lag with that, but really, how much more off the line power do you need with a V8? And after you get traction and the turbo spools, you are gone.
Old 01-05-2004, 04:07 PM
Instantaneous response from a T88, even hooked up to a V8, is a bit of stretch.
Old 01-06-2004, 08:50 AM
Ok. But there sure won't be ahrdly any lag at tall though. Considering that Supra's run T88's and get full boost at 4700 RPM on a 3.0L engine. Now with a 5.7L engine, that would roughly half the spool time so full boost would be around 2300. Your right, instantaneous full boost is wrong, but that turbo will begine to spool up as soon as you press the gas.
Old 01-06-2004, 06:45 PM
How do you figure turbo lag is linearly related to engine displacement?
Old 01-06-2004, 06:50 PM
exhaust volume is increased linearly with displacement.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
