Old 12-31-2003, 08:34 PM
c a m a r o c a m a r o is offline
Banned
transmission problem
my friend has a problem with his transmission, it switches into all gears fine, but when you let go of the clutch it the car wont move, it doesnt even stall. my guess is his clutch is burnt. i was there when it broke... he was racing this car and when he tried to switch it into third gear it didnt go, it made that grinding noise. then it rolled in 4th gear fine for a few blocks after that (1 and 2nd had almost no power) until it completely stopped moving.
Old 12-31-2003, 09:27 PM
KC Ron Carter KC Ron Carter is offline
Hmm
Your friend needs to get that car to a mechanic.
No way to determine the issue from the discription.
Later,
Old 01-01-2004, 12:29 AM
454Casull 454Casull is offline
Re: transmission problem
The synchros might be destroyed. Or, in the worst case, the gear teeth are stripped.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 01-02-2004, 10:10 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
most likely a fried clutch, which causes further damage to the tranny.
In other words, he is screwed, for now at least.
Mustangs are nice, but I'd rather have one of these...
Old 01-02-2004, 08:03 PM
A clutch making a grinding noise?
Old 01-03-2004, 07:49 AM
he said that it grinded when he tried to put it into gear, meaning the clutch was not engaged.
Old 01-03-2004, 08:32 AM
Banned
he told me he pressed the clutch all the way down when he tried to shift into third, he tried it 2 times and it wouldnt shift, so he put it into 4th, and it went for a couple of blocks until the car stopped moving completely. which is why i think its the clutch, cuz 4th gear is easier to grip with a bad clutch than a lower gear. but thats only a newbie guess, not a diagnose... im 17 im not a tech guru..
Old 01-03-2004, 08:46 AM
I agree, try to adjust the cable to get the last bit of grip out of the clutch.
that will only last a very little while though, you really should get a pro to look at it.
Old 01-03-2004, 09:41 PM
The Dude The Dude is offline
how does a fried clutch damage the tranny.
Old 01-04-2004, 07:24 AM
It doesn't in and of itself, but driving with a clutch that does not fully engage or disengage will certainly hurt the synchros and the gears themselves.
Old 01-04-2004, 01:00 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Re: Re: transmission problem
I can see how a clutch that doesn't disengage would be a problem, but I'm a bit puzzled about how one that doesn't engage would hurt the transmission...
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 01-05-2004, 09:32 AM
If it does not engage, you end up having to force it, getting that grinding noise.
not as bad as failing to disengae though.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
