Old 12-31-2003, 08:01 PM
prits_uk2002 prits_uk2002 is offline
Cool heater and cooler fan making a load humming sound?
hi this is my first post so sorry if i have placed it in the incorrect area, i have a honda civic 97 3 dr hatch on the fans the cooler/heeter when i turn it above 2 it starts to make a weird humming sound can any one help?
Old 01-03-2004, 09:34 AM
QuakeWork120 QuakeWork120 is offline
Send a message via AIM to QuakeWork120
Yes, I can help you. Fans don't move without motors. Motors make humming sounds when you turn them on to high speeds.
No, but really, I'd check to make sure the fans aren't stuck by debris. The motor may be going out. What kind of humming noise is it? Is it very loud? How close is it to the original sound of the motor?
1997 Acura Integra GS-R
-AEM CAI
Old 01-03-2004, 05:12 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
probably just some dust in the fan blades.. get a hold of a 90 PSI or higher compressor, and a piece of hose to stick in the air inlets, and blast away... be ready for dust in the face... also helps to keep your AC from blowing dust as much when you turn your car on in the summer... Plus that should help a bit reatable fabricewith the dust problem, best bet would be to take the fans out and clean them.... go to your local VIP, Auto Zone, or Auto supply store and get the manual for your year car, and( about $14) and look up the ventilation system, and how to take it out/ dismantle it.... should be able to do it all yourself from there, and take a good rag/cotton swabs to the fan, and housings.. and blast the air hoses/vents..to prevent it in the future, go to a local fabric store, and find some breathable fabric and cover the intake of the fan (lightly you still want airflow) kinda like a filter... If you can get filter element stuff, then use that.. that should help a lot....
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
