Go Back   Automotive Forums Car Chat > Mercedes-Benz > General Discussion
Old 12-31-2003, 06:49 PM
isidro69 isidro69 is offline
1982 240D not running
I have a 1982 240D mercedes diesel.
I was out of fuel and poured old diesel fuel into the tank.
It still won't turn over.
Someone said I need to "Prime it".
Is that correct?
How do I prime it?
Is there anything else I should be doing to get it to run?
Old 12-31-2003, 07:00 PM
hi you thank you
Old 01-01-2004, 07:59 AM
mechy1barry mechy1barry is offline
Re: 1982 240D not running
you say it won,t turn over?or do you mean it won,t fire?any way if you ran out of fuel,the filter will be dry and possibly causing an air lock.if you can, try pouring fuel into the filter, and slightly undo two injectors at the pipe unions and try to start,this will help to release any air in the system.but be prepared to flatten your battery!!
Old 02-25-2004, 08:40 AM
phbrown48 phbrown48 is offline
Lightbulb 240D not running
I hope that you have it running by now. If not, you need to prime the pump. Just below and to the left of the in-line plastic fuel filter (found near the oil dipstick), you'll see a 1 1/4" diameter wheel. That is the top of the priming pump. Turn the wheel counterclockwise and lift it up and down. You'll note some movement of the air bubbles in the filter. Keep pumping until the air bubbles disappear, and pump a few more times. This puts fuel in the injection pump. Turn the wheel clockwise when you are done.
Now charge the battery and start the car.
1982 accord wont run. slickmickey Let's get Technical! 0 02-23-2010 06:48 PM
1982 240d Mercedes-Benz Turbocharger neolancet General Discussion 2 01-15-2006 04:19 AM
92 Mercury Marquis running lights on all the time even when car is not running debdenis Grand Marquis 0 02-03-2005 07:30 PM
Tranny shifts fine when engine is not running but, shifts hard when engine is running CR50HC '88 - '91 Civic | CRX | Wagon | Shuttlee 6 08-01-2004 02:54 PM
For Sale: 1982 240D mbz1231982 General Discussion 0 09-21-2003 06:03 PM
