Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 12-31-2003, 05:22 PM
don.j.pearson don.j.pearson is offline
2000 Wrangler "clunks" at initial motion
I've got a 2000 4WD Wrangler with 20K miles on it. Bought it new. It also has the locking differential. During the past few couple of years, I've noticed a repetitive clunking sound occassionally when I back the vehicle up. It's more pronounced when the vehicle has been driven and is warmed up. It also happens sometimes when turning (not hard turns). When it does clunk, it will do so for maybe 2 or 3 seconds and then goes away. This is an intermittent problem and, of course, the dealer could find nothing wrong with it. Other than this annoyance, the Jeep is in excellent shape and has been "babied" as far as offroading is concerned. I don't think the clunking is due to the rear drum brakes chattering nor do I think it's due to the emergency brake release, since it'll happen after driving around for 20 minutes. Sound appears to be coming from the rear. Anyone with similar experience???? My email is [email protected]
Old 12-31-2003, 06:53 PM
Bronco2 Bronco2 is offline
Re: 2000 Wrangler "clunks" at initial motion
I am not a jeep expert,it sounds like the clutches in the differential hanging.I have had this problem before with other cars.If you have a local rear end guy,ask him what he uses as a "friction modifier/limited slip additive " NAPA sells a good product,but I would double the amount.Use a suction gun to remove enough oil.You could drop the cover and change the oil,but it is probably filled with synthetic which gets expensive quick. Check your manuel or the local parts store for specs.Also,I have not seen the clunking really hurt anything,its just annoying
Security System In 2000 Wrangler tylot3 Wrangler 2 08-24-2004 05:45 PM
2000 Passat GLX 4 motion Gdub65 '97+ 1 04-14-2004 05:36 PM
2000 Wrangler Starting Problem tricky_karma Wrangler 2 03-01-2004 02:56 PM
2000 LeSabre rough initial acceleration (new to AF) Jaud17 LeSabre 12 02-06-2004 10:08 AM
2000 Wrangler Steering jamkass Wrangler 0 11-28-2003 07:39 AM
