Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 12-31-2003, 05:14 PM
Mystics7 Mystics7 is offline
Send a message via MSN to Mystics7
Lightbulb RS3200 Upgrade
I got an upgrade kit for my 04 Taco and found the wire to disco to enable the alarm featur. I am having trouble finding the connector to plug in the LED Display/Glass sensor. Any help would be greet.
Old 01-02-2004, 06:34 PM
elaclair elaclair is offline
Re: RS3200 Upgrade
Hey Mystic, I'll trade ya. I found the connector for the Display/Glass sensor, but couldn't find the wire to enable the alarm.
The connector for the display is actually tucked up behind the center console. It's taped to another harness and is a bit of a pain to get down. just removed the center console and unplug the two power ports. If you follow the cable for the power ports with your hand, you'll bump in to the connector up behind the dash. Just untape the connector and it will have plenty of length to reach the center console.
Now, if you could tell me where the enable wire is.......:-)
Thanks!
Ed
Old 01-03-2004, 10:52 AM
Thank you. I will take a look later today. If you take off the panel under the steering column there is a small connector called the P1 connector. I will take a picture ASAP and send it to you also you can email [email protected] with a fax number and the will send you the instructions that clearly display the one you looking for but not mine. Thanks again for the reply any question let me know.
Old 01-03-2004, 12:03 PM
Thanks for the reply. I went back and looked again, and discovered the P1 connector right where it was supposed to be.....must have looked there a dozen times before. Guess I was just frustrated about the display connector...go figure. Anyway, I now have a fully functional RS3200+ for $400 less than the dealer would have charged me.
Thanks much!
Ed
Old 01-03-2004, 02:11 PM
The connector was exactly were you said thank you very much. Yea when i picked up my truck with the Key less entry system; they said it would be 350 for the VIP RS3200 alarm up grade..... Well i found the Status light and glass sensor on Ebay for $70. And now also have the full system. Thanks again!!!!!!!
Old 02-06-2004, 01:14 PM
nmdesperado nmdesperado is offline
Re: RS3200 Upgrade
Thanks much!
Ed
I am having the same problem and don't know where to look or what to look for (color, size, shape) for this mysterious P1 that isn't mentioned in the installation guide (for the entire system). Any help locating the connector would be appreciated.
Old 03-11-2004, 07:19 PM
'03trd '03trd is offline
I believe this is the only time I have left a connector disconnected and actually had something work as it is suposed to!
Damn fine and FREE mod!!!!!
I just bought the RS 3200 shock sensor, E-Bay, for $66.
I plan to get it in this weekend.
Thanks to all.
Happy trails........................................
2005 RS3200 alarm install help kevlar119 Tacoma 1 08-22-2005 02:22 PM
toyota keyless entry vs. rs3200 chuey11 Camry/Camry Hybrid/Vista 1 02-17-2005 05:20 AM
F/S 2000 Camry RS3200 alarm JWatson Camry/Camry Hybrid/Vista 3 09-20-2004 09:57 PM
2004 RS3200+ Upgrade nmdesperado Tacoma 2 02-08-2004 12:40 PM
RS3200 upgrade from keyless entry mtstream Tundra 1 12-28-2003 07:29 PM
