Old 12-31-2003, 04:01 PM
mstngcobrasvt98's Avatar
mstngcobrasvt98 mstngcobrasvt98 is offline
Send a message via AIM to mstngcobrasvt98 Send a message via Yahoo to mstngcobrasvt98
Cruise Control Problems
I've searched on this and i'm just posting to confirm. My cruise control coesn't work at all. On/Off doesn't turn it on. I hooked it up to a computer diagnostic system thing and no code came up. As far as me and a close auto mechanic can tell, everything is hooked up where it needs to be. So, im gonna try a new cruise control unit. How much does a new/used one run? Any help is appreciated. Thanks.
Just a good model of mine:
2 Fast 2 Furious Skyline
STOLEN!!!
Another go at it:
2 Fast 2 Furious Skyline.. Pt. 2
Old 12-31-2003, 04:25 PM
RABarrett RABarrett is offline
Re: Cruise Control Problems
Whatever it costs, it will be more expensive than repairing the original. A good tech can repair what ails these units, whether they set codes or not. Food for thought. Ray
Old 12-31-2003, 05:57 PM
ottoracefan's Avatar
ottoracefan ottoracefan is offline
If you're talking about replacing the cruise control servo unit under the hood which contains most of the cruise control components, I've bought and installed 3 of these on various GM cars. Paid $30-40 for each at salvage yards, it fixed each car, and they were all still working when the cars were sold/traded.
Check http://www.car-part.com/ if you don't find it locally.
Old 12-31-2003, 07:19 PM
what about just the control level on the steering column?
STOLEN!!!
Another go at it:
Old 01-01-2004, 09:03 AM
Re: Re: Cruise Control Problems
You should be able to check the column switch for the cruise control with an ohm meter. The servo under the hood can usually be switched in a few minutes - - any chance you know someone with a similar car you could swap servos with so you would know if that part is good?
Old 01-07-2004, 10:37 PM
I dont know anyone right off hand with a LeSabre i can ask to borrow this part. I'll try to check the column switch. Are there certain wires I need to check? I'm only 17 and need a cheap fix. No mechanics if possible. Thanks.
STOLEN!!!
Another go at it:
94 Ram no cruise controll mrkabokieman Ram Pickup | Ram SRT10 3 08-16-2009 03:36 PM
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 10:41 AM
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 10:59 AM
Climate Control and Cruise Control Problem yakko Regal 12 10-03-2007 07:52 AM
'94 ABS / Cruise Control Problem as well as window problem cwru53 Cutlass Series 1 06-16-2005 09:35 PM
