Wind noise
I took delivery of my accord ex v6 and noticed that there is a lot of wind noise coming from the passenger window (?). I took it back to the dealer and they said that is was normal... I say no way! I would like to know if anyone else has encountered a disturbing amount of wind noise coming from the passenger side. Is there a fix for it? You start to notice it when you hit 45mph or higher.
Re: Wind noise
ask dealer if you can test drive identical car, to see if it has same noise.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB Electronics: Apexi VAFC (untunned) Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar. Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2 Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads |
I had the same problem only on the drivers side. The amount of noise was just ridiculous. I took it to the dealer twice with no luck. Did a ton of research and testing on my own. Discovered a missing rubber body plug on the bottom of the car. Put a piece of masking tape over it and the problem was fixed. Have no idea how sound got from under there to the area near the drivers seatbelt but it did. Had the dealership order an actual plug. Everything has been perfect since. I still think the Accords could use some work in the noise area.
I kind of have a wind noise and It might be the same. Where is this body plug? right under the door? I thought the noise was a result from the wrinkled Molding they had to replace for the 20th time! Thanks.
