Old 12-31-2003, 02:49 PM
cj99 cj99 is offline
97 3.3 dies while driving - hard to start
Died on my wife. She said it died while they were driving down the road abot 40mph. Started right back up again. I also noticed it has been harder to start lately. Turns over quite a while then almost doesn't start.
Any suggestions?
Old 01-01-2004, 11:33 AM
gforster gforster is offline
Re: 97 3.3 dies while driving - hard to start
I would first suspect the Idle Speed Motor. About the only real way to check it out is with a scantool (shop) Also I would look at fuel pressure/pump/filter.
Maybe go as far as to hook up a fuel pressure gauge to the fuel rail and monitor it when the engine does this dying thing... Are there any codes stored?
Old 01-01-2004, 10:34 PM
MegaMax MegaMax is offline
Send a message via AIM to MegaMax
It may also be the Cam Position Sensor (sp)
That too will cause it to stall when driven...
MegaMax
  • Suspension:
    Ground Control CoilOvers, $tillen FSTB, RSTB, Addco RSB
  • Lighting:
    Clear Signals, ALL bulbs Hyper White, Rewired Signals, Brighter Corner Light Mod, Rewired Fog lights, Blue Neon Headlights, Hyper White Washer Nozzles, Blue Under Car Neon, Blue Neon Under Dash, Custom wired Tail Lights
  • Cosmetic:
    Blue Break Calipers, ALL Windows Fully Tinted, NisMO badge on rear
  • Performance:
    TB Coolant Bypass, Cattman Jet-Hot Y-Pipe, High Flow Cat, Greddy Catback, $tillen HAI, Unothodox Racing Underdrive Pulley
  • Other:
    Optima Battery Relocated to Trunk,NGK Platinum Plugs, Synthetic Motor Oil (Every 5K), Synthetic Trans Fluid, 93 Octane Fuel ONLY.
  • Best E/T:
    15.4 with just the $tillen HAI 2 years ago… Now, go to the Track to find out..!
Dre's Corner
www.Maxima.Org
www.superstallions.com
www.f150online.com
Old 01-02-2004, 12:41 AM
Had the fuel pump and filter changed recently. I think the ISM was changed a few years ago. I too suspect cam position sensor because it almost acts like a timing problem.
Because of work schedule I have it at the dealership now being diagnosed. I will post the results.
Old 01-02-2004, 08:35 AM
The part is about $50.00 and it will take 1 socket and under 5 minutes to change it out.
Let me know what the dealer asks you for it if that is in fact the issue.
Only reason I know this, my van did the same thing and my uncle did the diag on it for free and I changed the part.
MegaMax
  • Suspension:
  • Lighting:
  • Cosmetic:
  • Performance:
  • Other:
  • Best E/T:
Dre's Corner
www.Maxima.Org
www.f150online.com
Old 01-02-2004, 10:25 AM
I just spoke with the dealership. Naturally after putting it on their computer they could find nothing wrong and they would not listen to my suggestion of the sensor so I guess I will change it out myself if its not to difficult. I priced them already - about $35.
I havent looked for it. Where is it located and how do I get to it? I wont effect the PCM by changing this will I?
98 Civic died while driving then started 10 min later jgr7 '96-'00 Civic 7 02-26-2010 04:22 PM
2002 grand am died while driving wont start staggs007 Grand AM 3 03-24-2008 04:57 PM
91 caravan died while driving wont start agian help! xratti Caravan | Voyager 1 12-05-2005 02:54 PM
2003 cavalier died while driving wont start cavygirl13 Cavalier Problem Diagnosis 3 08-25-2005 05:02 PM
'99 GA died while driving, wont start. tehman Grand AM 2 07-06-2005 01:58 AM
