Old 12-31-2003, 01:36 AM
crazzyyj crazzyyj is offline
Question please help me need info????/???
help plzz i just bought a used 1993 honda civic 4 dr .i dont know a lott about .whats under the hood ,does any won know what type of honda engine .i might have under their ,at leat it came with a carbon hood n cold air intake, the engine i was told is stock.does any won know what it might be.what horse power it might have? any thing is help full to me if u can tell me something .is it good bad ?? ill swape it out if it would be better?/ and can i find a lott of up grades for my car ?? body kitts and engine up grades??is thise possible to do?/// or did i fuck up and buy the wrong car?????/?? i do know on top of the engine . it says 16 valve .... and says honda motor company,, but thats all.. doesent say v tec .or doc/ or soc cam eather.. doese any won know ????????????
Old 01-01-2004, 01:57 AM
K20 si K20 si is offline
Re: please help me need info????/???
From my experience, I would have to say that your motor is a sohc v-tec because my cousin has a 93 civic also, except that his is a 2 door and on top of his motor it read sohc v-tec 16 vavle. Unless a 2 dr and a 4 dr motors are different but I don't think they are, and I'm pretty sure that the stock civic like that pushes out about 120 hp.Someone correct me if I'm wrong.
If you just want an OK looking car then stick with what you got and just up grade it a little, plus a new paint job and rims. YOU'LL BE FIND!!!
But if you want to go extreme with it then I reccomend you swap the motor to a LS v-tec, or the B20 would be the best way to go. A B20 can be a bit exspensive. My wife's cousin has a 4 dr integra with a B20 motor, si transmission, and a GSR head. Also with the basic done and a couple of internal up grade like cams, throttle body, and new pistols. All of that cost him close to $10,000. It was worth it because when I test drove it.......mannnn, that car got balls. It smoked my K20 si like nothing and I pushes out about 200 hp. I know that ain't much but that's 200 hp on a 1640 lbs car. That's only about 100 lbs heavier than the 91 CRX si. Besides, with what I got, I beated the RSX typeS like it stole something. But that is still not enough to take on my in-laws' B20. So with the light weight car like yours, a B20 would be perfect!!!
Old 01-01-2004, 02:12 AM
civic15.8's Avatar
civic15.8 civic15.8 is offline
ok if you know what kind of model civic it is like ex,lx,dx. if it is an ex then you have a sohc vtec if it is a lx dx then it is a sohc. It you dont know what type model civic it is then take a look at the door handles if they are black (not painted) then it is a dx, lx. If the door handles are painted the same color as the car then it is a ex.
yes there a plenty of bodykits and mods that you can do to your car
yes it would be better to swap also you have the easiest generation civic to swap. but a swap is way more then just pocket change. but it is all in what you want for your car.
hope this helps you out
95 integra ls
kyb agx adj shocks
ground control coilovers
I HAVE JUST BEEN TURBOED
future:
str intake manifold
17" rims
apex n1 exhaust
body kit
carbon fiber hood
We need more members: www.hondachat.com
