Old 12-31-2003, 01:32 AM
RKYGS-T RKYGS-T is offline
Send a message via AIM to RKYGS-T
Angry gs-t spyder boost guage
it would be a realy big help if some1 could tell my witch vacume line to conect the boost guage 2.....?
Old 12-31-2003, 03:27 AM
diviniti's Avatar
diviniti diviniti is offline
Send a message via AIM to diviniti
Red circle, make it look exactly like that with a T fitting.
Old 12-31-2003, 07:36 AM
kjewer1 kjewer1 is offline
AF - Advisor
Most poeple do use that line to get the boost guage signal, and I womt lie, I use it myself. But I dont recomend it to others without first giving the warning that if that line, tee, or guage fail, you could be in big trouble. That is the line that tells the regulator to raise fuel pressure 1:1 with boost. IF that signal doesnt get to the regulator, you run lean, under boost So my point is if you use that, dont make a hack job out of it. Do it right, and ziptie everything. Use quality fittings and lines. And Check it often for signs of wear. The 1/8th hard line that comes with those guages gets brittle over time and will crack eventually. Just a heads up
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
