Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-30-2003, 11:20 PM
Dru998 Dru998 is offline
Pop-up Headlights Stuck in up position?
My headlights went up and never came down . I hate the up look in the daylight. I checked fuses all ok. Could anyone explain how to check a relay for me? I know of two relays that might be the problem, one by the battery and the other by the air filter. Has anyone had this problem before and has solved it? Thanks for any and all help =D.
Old 12-30-2003, 11:52 PM
mrflip69 mrflip69 is offline
LOL... Did you press the button that pops them up without having to turn on the lights?
Old 12-31-2003, 07:09 PM
simounj simounj is offline
Re: Pop-up Headlights Stuck in up position?
i have the same problem... its annoying, haha
High End Performance
Ventura, CA
(805)644-8888
Old 01-01-2004, 03:13 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
you could just spend a minute manually turning the screw under the hood on each side to move them up and down, although not fun, it works... you can also use this method for a sleepy eye look
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 01-01-2004, 04:21 PM
LoL well it was an easy fix, was a fuse I had over looked called "RET MTR" Replaced it and everything works great =D. Cool, Im gonna try that turning the screw to make a sleepy look.
Old 01-01-2004, 04:36 PM
where did you buy the fuse from? was it one of those relays in that little black box?
Ventura, CA
(805)644-8888
