Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 12-30-2003, 09:58 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Strut Boot?
I was just wondering if any of you have rubber strut boots on your struts. When I put on my coilovers I had to get rid of the factory metal one. Now I have ordered a set of KYB GR2's and was wondering if it is necessary to use these or if it even matters.
Check out my car here My 91 Hatch
Old 12-31-2003, 02:23 AM
BullShifter's Avatar
Re: Strut Boot?
YES!!!!!!!! if the strut/shock rod becomes dirty, it WILL damage the seal. Resulting in, guess what? A nice leak & now you need a new strut(no warranty) because of a $15 part. Now is a good time to replace the upper strut mount bushings as well.
Don't forget to cut the bump stops in 1/2(shorten)
KYB makes both - www.tirerack.com
Old 12-31-2003, 11:57 AM
Re: Strut Boot?
Why cut the bump stops?
Old 12-31-2003, 03:39 PM
Re: Re: Strut Boot?
The bump stops should be cut to increase suspension travel reduced by lowering. You don't want to leave them off because you run the chance of bottoming out - metal to metal. Not only can it damage the suspension parts, it could hurt some one in the car.
