Old 12-30-2003, 08:18 PM
Bilson8tor's Avatar
Bilson8tor Bilson8tor is offline
Send a message via AIM to Bilson8tor
I thought I had an STD
ever since i've had the car i thought it was the STD, because in the owners manual that came with the car there was on a Si, LX, EX, DX, and STD, but i was looking up what all the numbers mean in my VIN number and according to my VIN i have a CX, but i thought the CX came as a 5spd and mines is a 4spd?
did i rember something wrong ? or did i miss a memo?
Old 12-30-2003, 08:40 PM
Magik Si's Avatar
Magik Si Magik Si is offline
What is the engine in the car? I know the stock engine in a STD (have one) is a D15B1....not sure what's in a CX but I'm sure someone else will pipe in...maybe put up your VIN so someone can decipher it for you?
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 12-30-2003, 08:50 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: I thought I had an STD
a cx is a STD. in canada they were called a cx. we call them the STD here in the us cause there is no marking on the back for what model it is. so its the base or standard model.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 12-30-2003, 09:12 PM
Magik Si's Avatar
Re: Re: I thought I had an STD
Not to argue...but my STD didn't have a marking...but I have seen cx's around that are 90's...and I'm in Canada.
Jason
Old 12-30-2003, 09:23 PM
Bilson8tor's Avatar
but my exhaust manifold looks loke the ones on all the non STD models, in the manual every car has the same manifold except the STD
btw my car has a D15B1
Old 12-30-2003, 09:34 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: Re: I thought I had an STD
Jason
cx's are from 88 - 91, some have the badge, some dont, i prefere without cuz it looks cleaner IMO mines a CX btw but it has the d15b2 with a 5speed taken outta a CRX (the previous owner told me that the guy before him swapped it so its pretty kewl) so once the ZC goes in, this car will have had 3 different motors and 4 different trannys lol
Old 12-30-2003, 10:00 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
I got bad STD once I could barely pee it hurt so bad.
Old 12-30-2003, 10:50 PM
riceriderjade's Avatar
riceriderjade riceriderjade is offline
hahah
2 points for that one
Old 12-31-2003, 12:45 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Jason
yeah, you arent arguing, he said the same thing as you. in US, its an STD because theres no trim tag assigned to the car, so people call it a standard or STD. in canada theres a trim tag, called CX, and its the same car.
you are correct sir. the 88 is the only STD to come with the HF style manifold, all the others had the catalyst under the car behind the engine.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 12-31-2003, 08:27 AM
Magik Si's Avatar
So I guess what everyone is saying is...yes...you DO have an STD/CX...all 4th gen hatchbacks were built in Canada at the Allison Ontario Honda plant...one way to tell is there should be a sticker in the engine bay near the hood latch that says "Honda Manufacturing of Canada"...plus the VIN will tell you too.
Jason
