Old 12-30-2003, 08:17 PM
DtB251
Guest
Posts: n/a
Help With Interior**
I Want To Hook Up My Interior By Making Everything In Their The Same Color. Where Would I Get The Proper Materials For This And How Would I Even Start. I Think It Looks Hot When People Do That To Their Cars. But I Have No Idea How To.....
Also Check Out My Post Below I Need Help With That Too
Thanks!!
Old 12-31-2003, 12:59 AM
Silverbolt Silverbolt is offline
Exterior Guy
Send a message via AIM to Silverbolt
Re: Help With Interior**
Here buddy, I moved your thread to the interior section.
"Take your time, do it right, and NEVER settle for less."
"The only stupid question, is the question not asked."
Old 12-31-2003, 06:00 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Thanks!!
First question...are you looking for simple DIY or are you looking into something a little more complex, like having a custom interior done by a custom interior shop. Second, prices on the proper mateiral varies...are you planning to use vinyl? leather? suede? a different cloth material? The costs all vary material to material. Second, do you want stuff re-wrapped? Doors? Dash? Seats? Or are you hoping to re-wrap the seats and paint or re-dye the doors, dash, etc...you need to give a little more detail into what you are looking for before anyone can really answer your question.
Old 12-31-2003, 02:28 PM
DtB251
Guest
Posts: n/a
Re: Re: Help With Interior**
THANKS FOR THE REPLY..I AM LOOKING FOR SIMPLE DIY. I AM NOT SURE WHICH MATERIAL WOULD BE THAT BEST TO DO IT IN. I WOULD LIKE TO DO IT CHEAP, WHICH MATERIAL WOULD YOU SUGGEST? I WAS HOPING TO RE-WRAP THE SEATS AND PAINT THE DOOR, DASH ETC. BUT I AM REALLY NOT SURE HOW TO AND WHERE WOULD I GET THE PROPER MATERIALS?
Old 12-31-2003, 02:51 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Re: Re: Help With Interior**
super fine grit sand paper
flat primer
semi-gloss (satin) spraypaint
semi-gloss (satin) clearcoat
Take out all your plastic parts, sand down the entire painting area and wash off with water, spray a few light coats of primer.. waiting about 5-10 min in between each one, then spray light coats of paint on top of that, waiting about 10 min in between coats, then 3-4 light coats of clear coat, and voila. The color of paint is up to you, but remember, make sure it's a color you really really want and make it clean so you don't get tired of, or regret it.
Old 01-11-2004, 05:13 AM
Honda God
Well, if you are looking for a material that is inexpensive, vinyl is relativly inexpensive. I perfer Nova-Suede myself, but unless you know where to go to get a good price on it, vinyl will be easier for you to find cheaply (though Nova-Suede may be a little easier to work with. If you re-wrap anything is vinyl, nova-suede, or another material, make sure to clean the surface very well first. Easy to find cleares that will help are a) srucbing and washing the panel with a ditergent like tide. These can be rather harsh, and wll clean off lots of crap. b) lacquear thinner will remove things like overspray and wax. Now, you would need a good contact cement too. After the surface of the panel is clean, you would spray BOTH the panel and the backside of the material with the contact cement. Let it sit for 5 minutes to get tacky. Wrap the material over the panel, smooth flat. That's a basic, very simple explanation of wrapping interior parts. Ricochet gave a simple expanation of how to paint. If you are gonna paint the WHOLE door panel though, fiberglass it first, then paint it. It will give you a much better finshed look. Fiberglassing isn't exteremly hard. If you arn't afraid if you mess up a few times, you'll be fine. To get Vinly, Nova-Suede, etc...open the yellow pages, and look up fabrics. Call all the places asking if they carry the material you are looking for in the color you want. Then if they do, ask there price per square yard for the material. For a Conact Cement, since I doubt you have an air compressor with a syphin feed spray gun, 3M makes some good contact cements in spray cans. Also, PER-MAC is also a good conact cement. You'll most likely have to look up upholstery in the yellow pages and call around asking if they have it and what they have, though a check of your local hardware store can yeild supirsing results. For Paint and Fiberglassing stuff, unless you are looking for the ultra high end professional products, there's no need to go to an industrail supplier (like Industrail Finishes), though you can almost certainly find contact cement like the strongest 3m one or PER-MAC there. A automotive sotre like shucks, kregen, baxters, napa, etc...should have spray paint and fiberglassing stuff to suit your needs.
Here is a decent link on the process of re-wrapping your seats, if you are unfamiler with the process.
http://www.teamgroundzero.net/doityourself.asp?id=409
