Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-30-2003, 05:09 PM
yoboricua yoboricua is offline
Lightbulb Running rough at idle and while driving???
Well, this car is giving me a headache and a half. I have replaced spark plugs, all vaccum hoses and O2 sensors. The car still running rough at idle and when at regular speed it feels like I'm running on six cylinders vice eight. Any ideas will be welcomed. Thanks
Old 12-30-2003, 05:36 PM
jlaird jlaird is offline
I didn't notice if your Aurora was a classic or newer model. I had a very bad miss at idle in my 98 and it turned out to be plug wires. I changed the coil packs before I did the wires. Several posts on the old Aurora site indicated bad coil packs were a common problem. I understand that on the newer model northstar engines the packs mount directly to the plugs so no ignition wires. Good luck.
Old 12-30-2003, 05:39 PM
Its a 1995 Aurora.......
Old 12-30-2003, 06:10 PM
Mine nearly drove me nuts until I changed the wires. It was like night and day. It ran like new after that. You might remove the plastic wire cover and observe the area in the dark with the engine running. You may see some arcing from a bad wire.
Old 12-30-2003, 06:12 PM
Auror_AH Auror_AH is offline
Re: Running rough at idle and while driving???
Yeah, My 95 is still rough at idle as well, and I have yet to come up with something to fix it. :o( I feel your pain yoboricua. If i figure out my problem I'll send my answers your way...
Amanda
1995 White on Black
[email protected]
www.geocities.com/aurorapride/ACNA.html
ACNA Site Owner and Administrator
Old 12-30-2003, 06:26 PM
binky binky is offline
On my '95 it was the coil(s) and plug wires. Remember, if one coil is bad, 2 cylinders don't fire.
Also, clean the throttle body and plate on both sides of the throttle plate.
Old 12-30-2003, 07:49 PM
problem solved....
One of my wires was arching (#3) and had a bad coil. Now is running like a champ.
Old 01-02-2004, 11:02 PM
dsatt12 dsatt12 is offline
2 months after changing plugs and wires to fix my misfire, I had a chunk of carbon foul a plug. Like binky, I've come to the conclusion that some periodic carbon removal from the throttle body is a good thing. I ran a good fuel system cleaner too (BG 44K).
Old 01-03-2004, 01:21 PM
Indy8's Avatar
Indy8 Indy8 is offline
Even with these injected high-tech engines, good old Marvel Mystery Oil can't be beat for top end cleaning and breaking excess carbon loose. Use 91 octane or better and a 20oz Chevron Techron Concentrate every 2 months, along with the A/C Delco plugs and wires as discussed in the "Valuable Northstar" thread. A plug wire could foul only under load without you even feeling it. Over time, this can fry the coil. I suspect this is what has been causing the bad coil problem in these cars. Modern coil packs should last the life of the engine.
Quality isn't expensive, it's priceless.
99 Caravan Sport Rough Idle and Stalling blase Caravan | Voyager 8 10-10-2010 07:48 PM
02 Trailblazer rough idle and check engine light rainmaninwa TrailBlazer | Trailblazer EXT 4 01-08-2010 10:02 AM
89 Mustang LX, rough idle and runs terrible. Ericdano Mustang Problem Diagnosis 2 11-07-2009 02:14 AM
99 cutlass is running rough in idle and while driving Beercommie Cutlass Series 2 03-09-2006 07:52 AM
Rough idle, dies while driving & gets HOT!!! Tarheel Concorde 1 05-14-2005 05:24 PM
