Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-30-2003, 04:51 PM
ggal ggal is offline
Angry Can't replace power steering belt!
1986 Olds Cutlass Cierra
Not a mechanic. Got no money!
Need to replace the power steering belt. Old b elt has already been cut off. Can't figure out how to do this! Got any ideas?
Old 01-28-2004, 10:51 PM
brakeman brakeman is offline
Re: Can't replace power steering belt!
The smallest pulley, besides the starter, is called your "tensioner" the route that the hose needs to follow is usually printed on a sticker under the hood. Get a wrench on the tensioner nut and pull or push the tensioner until you have enough slack in the new belt to slip it over the last pully. good luck
Old 02-06-2004, 11:44 PM
walty83's Avatar
walty83 walty83 is offline
Send a message via MSN to walty83 Send a message via Yahoo to walty83
take all the belts off, weave the power steering belt around yur fan and then onto its pulleys. Then replace the alternator and fan belts.
Justin Walter
1983 Hurst/Olds 307 HO. Dual Turbo Exhaust w/ catbacks, T-Tops, 4
spd OD w/ Lightning Rods, 58k,300 on rebuild. #433/3,001
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 07:41 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
94 Pontiac Grand Am replacing power steering belt Thewookiegod Grand AM 1 03-25-2007 10:35 AM
replacing power steering belt hp10 jes33 Maintenance 1 01-01-2006 05:43 PM
