Old 12-30-2003, 03:46 PM
radioralph radioralph is offline
adding amplified subwoofer to factory system
my 2000 silverado ext cab has the delco am fm casette and cd player factory radio and front and rear speakers. I am adding a 10 inch sub woofer with seperate amplifier. In order to switch the amp on and off remotely I need to axcess a switched 12vdc lead at the radio....can anyone provide the color code for the radio harness?? THANK YOU>
Old 12-30-2003, 07:33 PM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
Re: adding amplified subwoofer to factory system
There isnt a colored wire for the power source you need. The radio has an antena/remote pin going into the harness, but no wire comes out of it. Try to find that pin (one with a pin but no wire). Then while the radio is plugged in and turned on, test that pin with a test light. With the test light still touching that pin, turn off the ignision and open a door. The light should go out. You then need to somehow attach your amp's remote wire to that pin. Did that with mine, and it works great.
Amplifier/Subwoofer installation joshnumber21 Riviera 0 12-18-2007 05:13 PM
2003 envoy xl adding a subwoofer to factory radio wismo Envoy 0 05-31-2006 06:59 AM
infinity sound adding a subwoofer/amp spikeyhaired1 Ram Pickup | Ram SRT10 1 09-08-2005 09:30 PM
adding amplifiers to factory headunit any better options? jimcyzfr1 Engineering/ Technical 0 05-19-2004 01:38 AM
