| Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs |
I need to know how to program my keyless entry before I go crazy and pay the Nissan dealer an arm + Leg to do it for me.
If you know how please send Email. |
Re: 93 Pathfinder Keyless Entry Programing Info
hi, just recieved your email. I'm in the process of moving and have been unable to find the directions. I believe it is posted on here last time I saw it was around august. I remmber you have to hold the button down on top of the alarm, (located under the drivers seat), until it makes a certain tone. then press the alarm button. is it a new keyless entry or ?
found this for you, and it sounds right.
see if this works.... Set-up: Key out of ignition and driver's door open & unlocked & passenger's door closed and locked. Procedure: 1. Insert key in ignition and remove. 2. Press the driver's MANUAL door lock switch, LOCK to UNLOCK, 5 times. 3. Close and open the driver's door. 4. Press the driver's MANUAL door lock switch, LOCK to UNLOCK, 5 times. 5. Insert key in ignition and turn ignition ON and OFF... Once to add a new code. Twice to rewrite over ALL previously stored codes. Three times to confrim how many codes are stored in the ECU. 6. Remove teh key from ignition. The car will now respond back the selected mode by automatically locking and unlocking the doors... once to add a new code. twice to rewrite over all previously stored codes. one to four times (slowly) to show how many codes have been stored. If the confirm mode was selected the process is complete. Otherewise: 7. Press the transmitter switch on the key for 1 second. After the signal is received, the car will respond by automatically locking and unlocking the doors once. 8) Close & Open driver door 9) Press transmitter switch on the remote for more than 1 second |
the small button should be a "panic" button. when you hold it down it will set off the alarm. i used the same method as gypsy soul on my 94 and it reprogramed both buttons.
