Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 12-30-2003, 01:27 PM
jaws38 jaws38 is offline
Radio problems
My 1990 Oldsmoble 98 radio picks up overpowering static whenever I pass under power lines. Also the range is less than my wife's radio.
Any ideas?
Old 01-03-2004, 03:59 PM
weedahoe weedahoe is offline
Send a message via AIM to weedahoe
Re: Radio problems
replace the radio with an aftermarket radio.....seriously
Old 03-24-2005, 07:13 AM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
Re: Radio problems
mine isnt that bad, but yea, get an aftermarket radio, even a cheap one will be better.
Old 04-02-2005, 01:16 PM
mxkeno mxkeno is offline
Re: Radio problems
Any ideas?
An antenna fault would cause this problem, make sure the cable is securely plugged in and then check to see it's grounded to the fender.
If you have a Loc. or DX switch it should be on DX (for distance)
F-250 radio problems...Need help farmboy401 F Series 0 05-10-2010 07:10 PM
Radio problems/ Rt rear window won't move/ Lights dim when shifted in Reverse Baxoid Grand Prix 2 01-03-2010 06:50 PM
please help monsoon radio problem friend cut harness into back of radio 94cordvtec Grand AM 1 11-12-2009 10:07 PM
2000 Cabrio Does not initially start, Radio Safe, Clock 1200 ptb123 Cabrio 0 04-11-2009 05:10 PM
DRL problem plus radio problem PyroTech General Discussions 0 03-16-2005 05:07 AM
