Old 12-30-2003, 11:56 AM
PLOW BOY PLOW BOY is offline
2002 Tahoe Fuel Pump Problem
I own an 2002 Tahoe with 62,000 miles. I did not purchase the extended warranty. About 2000 miles ago the car stopped cranking when the fuel tank had less than 1/4 tank. By adding a couple of gallons it would start. Then it starting dying on the interstate. If I pull over and waited a few minutes it would crank back up. My dealer tried to look perplexed and told me that GM had no official bulletin out yet, but they were experiencing plenty of problems. I have changed the fuel pump and bent the float mechanisim up 1 inch. Had no problems until this morning. It would not start until I added 2 gallons of gas. Also changed fuel filter several times, tank was clean when pump was changed.
Need help, wife's car, she is not happy!!!!!!
Old 12-30-2003, 12:47 PM
BullShifter's Avatar
Re: 2002 Tahoe Fuel Pump Problem
This is a Honda/Acura section . . . .try here http://www.automotiveforums.com/vbul...lay.php?f=1108
Old 12-30-2003, 02:40 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Re: 2002 Tahoe Fuel Pump Problem
Refill the tank at 1/4 full then..
1991 Regal Custom- Possible Fuel Pump Problem snickerkisses Regal 1 02-10-2010 10:08 PM
93 suburban fuel pump problem. robert1984 Suburban 2 12-15-2009 02:21 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
2002 Tahoe Fuel Pump michaelsjm Tahoe 2 04-18-2005 08:54 AM
