Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 12-30-2003, 11:11 AM
madnat41 madnat41 is offline
Dexcool
I own a 98 Pontiac Transport Montana. I am facing a $600 repair bill to correct a leaking lower intake manifold. My mechanic attributes this problem to using DEXCOOL. I have also seen numerous other complaints regarding the use of DEXCOOL. Question#1: Is there a problem with DEXCOOL? Question#2: If there is a problem, how do I get GM to pay for my repairs? Question#3: Do I keep using DEXCOOL or switch to the regular green coolant? Please comment. Thanks.
Old 12-30-2003, 02:51 PM
ciras3's Avatar
ciras3 ciras3 is offline
Re: Dexcool
Hi,
There are plenty of websites that claim that dexcool and intake manifold gaskets aren't compatible. I think there is even a class-action lawsuit being threatened, but GM is denying any responsibility. Here are some cool websites which can help you with your questions.
http://www.geocities.com/b_gillie/dexcool_problems.html
http://www.consumeraffairs.com/autom...m_dexcool.html
As far as switching from Dexcool to the regular "green stuff" many people are taking the Dexcool out of their cooling systems. All you have to do is flush out the dexcool really well, and use the green stuff.
If you need more information about this, use any Internet search engine and type in Dexcool Lawsuit, you will find plenty to read.
C. Smith
"Just because the cat has her kittens in the oven doesn't make them biscuits."
Old 03-06-2004, 11:11 AM
ritacpa ritacpa is offline
Re: Re: Dexcool
Welcome to my world. Last year my 98 Transport was going through a midlife crisis. My engline light kept coming on and the code always came up as the EGR Valve being the problem. Well, then after many many trips to the dealer to get this figured out, the van started overheating and I was losing antifreeze, none of it externally. It also had a rough start and ran rough until it was warmed up. I was informed the sad news that I was burning up the antifreeze internally and my cylinder heads were warped. So be thankful if you can get by with a $600 repair, my repair cost me $3000 to have my cylinder heads rebuilt and a new intake manifold gasket replaced (automatic on this repair job). I did switch to the green antifreeze after this experience, since I too have researched the cause of this happening and found many complaints that the dexcoolant was not so great afterall. My father, a retired mechanic, wasn't a big fan of the dexcoolant anyway, so now I am using the green coolant. Good luck. BTW, my van is running fine again but it was nine months of ##@@!!
Old 03-18-2004, 07:31 PM
daman daman is offline
Hi, nothing wrong with DEX at ALL it's great, i use it in all my rides listed below even in my '85 chev 4x4 not one prob. not ONE, my
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 06-26-2007, 02:12 PM
brlee74 brlee74 is offline
Re: Dexcool
Your right, dexcool is junk. Why replace green when there was nothing wrong with it in the first place. Had my upper intake gasket replaced, mechanic at dealership said this is pretty common. Check TSB for the problem, dealership is using a different type of gasket when they do the work, did they tell you that.
To DexCool or not to DexCool? That's the question. dksram S-10 6 07-02-2008 03:29 PM
Dexcool or non Dexcool? M330CSi Grand AM 3 07-03-2006 09:20 PM
To DEXCOOL or not to DEXCOOL? deb1poet General Discussion 22 03-27-2005 09:04 PM
dexcool enriqkike C/K 4 12-14-2003 08:39 PM
Dexcool = Death?!?!?! Madigon Mustang Talk 5 07-20-2003 02:49 AM
