Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 12-30-2003, 10:30 AM
c_jarrell c_jarrell is offline
Question 1994 525i Headlight replacement
Hi,
My Low Beam head light lense is cracked on my 1994 525i. Need help on how to replace it..
Note: this car actual manufactured date is 09/1993
Thanks
Old 09-04-2005, 09:05 PM
Johnny13o1 Johnny13o1 is offline
Re: 1994 525i Headlight replacement
I have the same problem. Anyone?
Old 03-15-2006, 12:10 AM
jdthorpe jdthorpe is offline
Originally Posted by c_jarrell
Hi,
Thanks
You must remove the turn signals in the grill by removing the nuts behind the lights from under the hood remove the plastic covers above the headlight assembly under the hood on top of the core support first to access the nuts easier remove any screws from inside the front of the grill that you can see you must also remove the center of the grill aswell but before you can do any of this you must remove the bottom metal strip it snaps on and you must remove it carefully so you don't crack you grill then remove the center piece of the grill them the right and left pieces then you can acess your headlights.
Old 03-15-2006, 12:45 AM
jbinsure jbinsure is offline
I would say, with all due respect....buy the Haynes / Chilton/ and/or Bentley manual. The first two being least expensive (under $20 USD) and the latter being quite expensive ( $75 and up ). They detail the procedure quite well and you are certain to make less mistakes. Trust me....I tried to do these seemingly minor repairs on my own and had I had the manual, it would've paid for itself 10x over.
My $.02
Jeff
1994 Buick Skylark Hazard Relay Replacement skylark94 Skylark 0 03-24-2009 09:39 AM
2004 525i coolant replacement boatingdobbins 5 Series 0 06-02-2007 09:22 AM
1994 525i ENGINE & PARTS FOR SALE!!! mikewilsoncars 5 Series 3 01-17-2005 09:27 AM
1994 525i andrew1992 5 Series 1 08-27-2004 10:51 AM
E34 1994 525i Parting Out - Your Prices! MALIX 5 Series 5 01-09-2004 09:00 PM
